Hi All,
Need some help with virtual dj 7 and mixtrack pro headphone setup.
I resumed djing after a while so unsure of where i am going wrong,
As the original config did not work i moved to advanced.
Problem is i cant get the headphones to give me cue, if i try any combination for headphones the cue mix and the cue gain turns into volume control and the headphones gives master,
I have tried countless videos and google articles but nothing has helped,
All virtaul dj combinations have also been tried like advanced config, original config with numark as sound card, new cables and headphones have been purchased, but no luck so far.
Posted Thu 04 Apr 24 @ 6:29 am
I have Mixtrack Platinum and config should be the same.
Have a look if yours matches mine!
Posted Thu 04 Apr 24 @ 12:04 pm
It won't match as the user is for some reason still trying to use ten year old software (without a license).
Posted Thu 04 Apr 24 @ 1:16 pm
