I am using an older Macbook that is 10.9.5 Mavericks. I've been using Virtual DJ Pro on it for years and it works great. I'm trying to connect a NuMark Mixtrack Platinum mixer to VDJ 7 Pro and it shows up in the drop down menu under settings but the buttons/sliders/knobs on the mixer are not reacting on the VDJ 7 Pro interface. My Macbook says there are no updates available so getting Virtual DJ 8 wouldnt help since I can't update the system on this older Macbook. Any help is appreciated.
Posted Fri 08 Mar 24 @ 7:06 pm
you can update to v8, not, the newest v8 but upto 2020, look at the bottom
https://www.virtualdj.com/wiki/Minimum%20system%20requirements.html
Posted Fri 08 Mar 24 @ 7:18 pm
