I have the FLX-10 and the left deck works perfectly fine. While I'm messing around and mixing the loop will show up on the right deck screen as normal just like left. Everything works as normal except for the white part of the loop won't show up in the waveform on the top of your screen. Any ideas? I restart the program and it works for a little bit then the loop stops showing up again. Restarted computer and same thing happened. Loop doesn't show up until you hit play. Left deck is completely normal.
Posted Sat 24 Feb 24 @ 10:50 pm
Update even with unplugging the controller and clicking on screen loop button it doesn't show the loop in the Top Waveform section on screen so, possible software issue? 16 "MacBook Pro M3 Max
Posted Sat 24 Feb 24 @ 10:54 pm
Another update both decks do this same thing. LOL Not sure why. If anyone has any thoughts please let me know. Thank you.
Posted Sat 24 Feb 24 @ 11:10 pm
