Topic: VDJ (with stems) / Synesthesia / Spout issues...
I've been experimenting with the excellent Synesthesia visualiser recently, and have to say I'm VERY impressed with what it can do! However...
After extensively testing (two full days) without issues I used the combination for a gig. Synesthesia decided to crash twice then crashed AND locked access to VDJ, which meant a Laptop reboot mid-set.
I know I'm pushing it with using stems and Synesthesia together, but it worked fine for two days. The i7 was capable and the RTX 3060 was hovering around 40% in general use, up to 80-90% for about 15 secs whilst computing stems. The framerate of Synesthesia dropped from between 60-150fps to 15-20fps while computing stems. Not ideal, but useable given the overall effects. (I also have the option of turning off stems of course!).
I output Synesthesia to VDJ as a video FX using Spout.
Another option I have considered is to use XSplit/OBS and Synesthesia on another machine, porting the video output of VDJ to OBS on that. This complicates matters as I would need to get the video to the other machine without much lag, AND access the second machine with remote desktop or similar (proposed machine is a NUC11 Enthusiast RTX2060/i7).
Any ideas how to approach this conundrum? Thanks in advance!
Kind regards, Rob
Posted Sat 24 Feb 24 @ 2:39 pm
why not use milkdrop2 by sbdj. 64 bit milkdrop plugin and works fantastic
Posted Sat 24 Feb 24 @ 7:40 pm
I shall look into it, but I doubt the features in Synesthesia are available with milkdrop2.
I had many happy years with the original milk drop, but the flexibility and image/video manipulation in Synesthesia are superb! Well worth checking out their YouTube channel if you have not seen what it can do. My only issue is that I've paid a lot for the standard edition, but currently unable to incorporate it.
Posted Sun 25 Feb 24 @ 1:29 am
I am looking into NDI with a second machine for visuals/streaming... hopefully it will be a viable idea!
Posted Sun 25 Feb 24 @ 1:31 am
Wow, I'll stick to the free milkdrop2/64. It's free and looks fantastic.
Posted Mon 26 Feb 24 @ 4:18 pm
NDI should give you better results, plus you only need the "Preview" window so it should be less taxing on your system as well.
Posted Mon 26 Feb 24 @ 7:10 pm
