Hi,
how can I create a colored filter in the search view, with a condition to the existance of a certain cue point?
Like, I want to color every trackk in magenta who has the Cue5 point set.
Unfortunately the following does not work:
I assume this is more a true/false or 0/1 condition.
In script I would simply write
It is possible to chech the existance of a certain point in color rules?
Thanks
Has cue points = 5
has_cue 1.
Thanks
Posted Sat 17 Feb 24 @ 1:44 pm
No, that is not available in color rules
Posted Sat 17 Feb 24 @ 1:50 pm
And it can probably also not be simulated with the "User1" settings?
Posted Sat 17 Feb 24 @ 2:00 pm
If you put something in the user1 tag for every song that you want to be magenta then of course you can do that.
Posted Sat 17 Feb 24 @ 2:13 pm
If windows I have a app that can find this kind of thing and it generates a list of files found.
You can then mark them in one go.
Posted Sat 17 Feb 24 @ 2:24 pm
1 minute videmo
Posted Sat 17 Feb 24 @ 2:51 pm
