Hi,
I have the Roland DJ505 TR and have noticed I have no TR/Sampler output when using the controller with VDJ. Can confirm it works otherwise and it has worked with VDJ in the past?
Hope someone has and idea.
Cheers,
Cheers,
Posted Sun 11 Feb 24 @ 7:23 am
user24625738 wrote :
Hi,
Cheers,
Cheers,
I use the Roland DJ-808 and all seems to work fine, what exactly are you trying to achieve? Do you use the built-in drumcomputer to trigger your own custom samples?
Posted Sun 11 Feb 24 @ 9:17 am
Hi, Yes I use the sampler to use custom samples and it all worked previously so it can only be a setting or there has been some change since the latest VDJ update. The sampler will work fine when not going through VDJ so trying to figure out what's changed?
Posted Sun 11 Feb 24 @ 10:59 pm
As a start of troubleshooting, i would use default Audio setup (especially the samplerin input) and factory Mapping
https://virtualdj.com/manuals/hardware/roland/dj505/setup.html
Posted Mon 12 Feb 24 @ 12:51 am
Hey, finally getting back to this response. Thanks for the info, I worked out the issue was a setting in the audio set up. Cheers for the help
Posted Wed 26 Jun 24 @ 5:07 am
