I attach an audio file, you can hear crackling, small noises during mixing. I hear this problem in my headphones and I find it in the VODs of my live shows. this problem is only present if I use stems, I don't know what to think. my PC is a desktop with i7 11700 16gb ram and geforce 3060 ti, I don't have any performance problems, if I deactivate the stems there is no problem. I listen to all advice.
link to mp3 sample
https://drive.google.com/file/d/1kCRJ9zb4PMBhYcatYJtI1_lu4XyKpAhv/view?usp=drive_link
this problem occurs when I start turning the knobs to mix
link to mp3 sample
Posted Thu 08 Feb 24 @ 3:11 pm
I believe it sounds similar to this thread:
https://www.virtualdj.com/forums/249996/VirtualDJ_Technical_Support/Pop_Click_in_the__2_0_Kick_Stem__particularly_House_genres______VDJ_2023.html
Posted Thu 08 Feb 24 @ 3:25 pm
thank you
Posted Thu 08 Feb 24 @ 3:45 pm
