Hi, I am trying to map the "Voc Echo" to my keyboard. I can't figure out how to pull the code and don't see anything online. I tried using the "eye dropper" but that doesn't give me the code. Thought it was this:
padfx "echo out" 80% 1bt "stemfx:padfx"
While close its not the same.
![](/img/398470/5121/Screenshot 2024-01-20 210726.png)
Posted Sun 21 Jan 24 @ 2:10 am
If you open the Pad Editor, then select the Stem+FX pad page, under the Pads Action section, you'll see the vdjscript code for that pad button.
Posted Sun 21 Jan 24 @ 2:03 pm
Thank you!
Posted Mon 22 Jan 24 @ 2:49 am
