Topic: Virtual DJ Remote for mobile Questions.
I have FLX 4 and own home plus license for reference.
My questions are regarding mobile app
1) Can I set cue points on my mobile or on my PC app and can they sync vice versa?
2) Can I just mix on my phone with my mp3's for testing and not have to be connected to my network. I want to make sure that I understand the application more. I may be on public transport just setting up transition points etc. Would these be able to be sync once connected back to my network?
3) Is it a lifetime, 1 time purchase like my Home plus License.
Hoping to find out more. Thanks.
Posted Sun 17 Dec 23 @ 3:26 pm
AdionPRO InfinityCTOMember since 2006
1. Yes, if you create a cue point on the remote, it happens on the pc
2. The remote is just a remote, so it can't work on it's own, it needs to be connected to your local network with VirtualDJ running on another computer.
3. Yes, it is a one time purchase
Posted Sun 17 Dec 23 @ 3:43 pm
So the cue points remain no matter what happens after so called set?
Posted Sun 17 Dec 23 @ 9:01 pm
Yes
Posted Mon 18 Dec 23 @ 5:01 am
Thanks. I bought it on the 21st and had a few plays about on it with limited time. I've found it to be good for the price.
Shame I can't play on my mobile with mp3 stored on mobile. It says what it does in the name, though.
Don't regret the purchase 👍
Posted Tue 26 Dec 23 @ 7:07 pm
