Topic: Help with DDJ FLX10 using stems in Virtual DJ
Hi,
I have downloaded 4-stem split plugin with Virtual DJ Pro and selected it, but when I was pressing the Stem buttons on DDJ FLX10 (vocal, drum, bass), nothing is happening at all. How to make them work together?
Posted Thu 23 Nov 23 @ 10:52 pm
Are you tryuing to use stems with Tidal perhaps?
Yes!!! Tidal is the only one so far I’m playing songs. But even w some downloaded songs, stems don’t get separated
edit: actually nvm, I was surprised to find out tidal doesn’t allow stem split anymore…
My other question is when I split stem of downloaded songs, only 1 stem can be active. (If I choose vocal, both drum and inst are off, same if I choose drum or inst). How do I have the other 2 stems both active by simply press on/off the stem I want to disable?
Whenever I use stems on my ddj flx10s I can’t use effects without it affecting the stems, as in If I’ve only got vocal stems on a track and try to use effects you start to hear the bass or instrumental and it clashes.
