I am thinking of getting the DJ2GO2Touch to use for my "low-end" gigs and I want to configure it where I just use the controller part for VDJ, but still keep my current USB audio interface connected to my PC (which provides 2 stereo output channels) for my main audio outputs to my sound system. Is this possible? Also, in this configuration, would I retain the cue function from the DJ2GO2Touch via its headphones? Basically, I don't want to use the device's audio output mini jack for the main sound output, but still keep all the other functionality intact.
Posted Wed 18 Oct 23 @ 1:34 am
Can't see any reason why not.
Just assign master to your interface and headphones to the DJ2GO2
Posted Wed 18 Oct 23 @ 7:04 am
Yes, you can combine any connected audio device any way you want
And it will work independently of the midi controls you sre using
VDJ may suggest a simpler config, but if you simply re-select the audio config settings and/or midi/mapping settings manually, you can get basically any combination for midi controller, midi mapping, audio master output and audio headphones/cue output you like
Posted Thu 19 Oct 23 @ 6:34 am
I bought it and it worked just as you guys said. Thanks for your input!
Posted Wed 21 Feb 24 @ 10:18 pm
