I've had this weird issue for a while. I think it's probably a problem with my controller (denon MC6000 MKii) but thought it was best to check here incase its an issue with VDJ.
So I'm using 2 deck mode. When I have a track playing on the left deck, if I bring up the volume on the right deck it inceases the speed/pitch of the left deck. it will sort of jump around and flutter between a few bpm. Oddly when the pitch shifter on the left deck is set slower/lower than the middle/starting position everything works fine and the other deck has no effect on it.
The issue doesnt happen when I just use my laptop to play VDJ , which is what leads me to believe its a problem with the controller.
But wondered if this had happened to anyone else and if there is a fix to it?
Cheers
Cheers
Posted Tue 25 Jul 23 @ 12:47 pm
