Hi, I am evaluatiing VDJ 2023.
When I have a long list of songs in the Automix or Sidelist panel, I cannot move a song from the bottom of the list to the top of the list because the window does not auto-scroll when the cursor moves to the top of the panel. This necessitates moving a song in stages several time up until you can eventually get it where you want it.
Can this panel be made to autoscroll when dragging a song up or down within the panel? Auto-scrolling is expected behavior in situations like this.
I usually would not have a lot of songs in these panels, but I just wanted to know in case I do have a long list.
Thanks.
Thanks.
Posted Fri 07 Jul 23 @ 4:19 pm
What I usually do is place the song that I want to move to the sidelist and removed it for Automix and and then find the spot where I want to move it too.
Another way, a bit awkward, when you use the mouse and click the song you want to move (up/down), while the button is pressed, scroll at the same time by using the scroll button on the mouse.
or created a script 'browser_move +1' this will make the song go down
browser_move -1 this will make it go up.
Posted Fri 07 Jul 23 @ 9:35 pm
Thanks, the script is a good solution.
Posted Sat 08 Jul 23 @ 10:08 am
I remapped a keyboard shortcut to SHIFT+UP (to move track it's location upward)
Posted Sat 08 Jul 23 @ 7:43 pm
