I am trying to locate and load the FX Stereo Channel audio plugin in VDJ > Extensions > Effects > Audio Fx, but I can't find it. I do see it on the VDJ website, though. What am I missing???
Posted Fri 28 Apr 23 @ 2:03 am
32 bit only, vdj can do sum mono with the script mono_mix if you need left only or right only sbdj released it on his site
https://forum.sbdj.co.uk/topic/3/sbdj-stereochannel-v2-0-released
Posted Fri 28 Apr 23 @ 2:22 am
I downloaded the zip file and tried running it, but I got an error (no worries). I appreciate the tip, though, Locodog. I will wait until someone creates a 64-bit version of StereoChannel.
Posted Tue 02 May 23 @ 2:31 am
It's there it works, but it's not really needed unless you want left or right exclusive mono, vdj can do sum mono natively with the script mono_mix
Posted Tue 02 May 23 @ 3:12 am
I made a custom button with the mono_mix script behind it and it was exactly what I needed. I didn't realize a script could be used for a button (I thought only plugins using a .dll was required). I learned something new - thanks!
Posted Wed 03 May 23 @ 12:50 am
