I'm trying to map a key to have this settings set when pressd.
Set Cue Name (done this part)
Set Cue Action (done this part)
Set Cue Color (done this part)
Set Cue Marker Only option (this is what I need help with)
here is the script for the above but missing the setting for "Marker Only"
set_cue 21 & cue_color 21 'Magenta' & cue_name 21 'pause' & cue_action 21 'pause' & (NEED TO PUT MARKER ONLY SETTING HERE ?"
thanks for the help
thanks for the help
Posted Thu 23 Feb 23 @ 4:32 pm
Can't be done with script, I've got some autohotkey style apps to do it but it's only good for point of creation.
Is this some apoi os2l kind of stuff?, I do have a thing for that.
Posted Thu 23 Feb 23 @ 4:39 pm
Yes... would be so cool if both Marker Only and Invisible could be also be set/unset via a script.
Then the whole tool box for scripting hotcues would exist.
Posted Thu 23 Feb 23 @ 10:00 pm
thanks for the reply Locodog.
Just making a simple scripts to make any adjustments I need to be easier.
Ah Well, maybe one day, this could be added.
Posted Fri 24 Feb 23 @ 3:05 am
