Hello,
I am new here and have had a Hercules Inpulse 500 since 6mnd. In addition to Djuced, I have switched to VDJ.
What I don't understand:
Can someone tell me the buttons sync on the HI500 and how they work together (or not) with VDJ.
I want to be able to decide if I want to sync or not.
Now it always syncs and would like to know how to turn this off.
These options are off in VDJ
On both decks:
BPM auto match
Key auto match
Auto sync on playback
Auto Pitch lock
and in the Options:
auto BPM Match
auto Pitch lock
I don't know where to look for it, but I want the syncing disabled.
I can't figure it out: where should I set something, and why don't the sync buttons with VDJ work like in Djuced => on or off (by choice)
Does anyone have any tips?
Thanks in advance.
Kind regards,
Ronald
On both decks:
BPM auto match
Key auto match
Auto Pitch lock
and in the Options:
auto BPM Match
auto Pitch lock
Thanks in advance.
Kind regards,
Ronald
Posted Sun 05 Feb 23 @ 9:02 am
Maybe go through these:
Posted Sun 05 Feb 23 @ 9:20 am
Hello,
Gone through the settings as per your video.
I noted that deck 1 always follows deck 2. The otherway around doesn't do that.
when playing deck 2, load a track deck 1 and play deck 1, bpm deck 1 always follows bpm of deck 2
when playing deck 1, load a track deck 2 and play deck 2, bpm deck 2 doesn't follow bpm of deck1.
Noted also that when I enable Quantize via the radio button (on both decks) both decks are playing their own bpm which is good.
So all these behaviours look a bit odd to me and also the sync button on my Hercules Inpulse 500 is close to useless as the light is alway on on both decks.
Can this be a kind of bug?
What do you think of this?
Kind regards,
Ronald
Kind regards,
Ronald
Posted Sun 05 Feb 23 @ 6:10 pm
Read here https://www.virtualdj.com/wiki/When+I+press+SYNC+the+two+songs+do+not+beat+match+perfectly+with+each+other.html specifically the last section about Master.
Posted Sun 05 Feb 23 @ 6:35 pm
Sorry but I really don't get it ;-(
I went of the 4 deck section and loaded on
A 130 bpm
B 118 bpm
C 136 bpm
D 126 bpm
(just to see what's happening...)
Play deck B 118 bpm no problemm then while deck B still running
press play deck C 136, no issue as no synching
press play deck D 126, no issue as no synching
press play deck A: jumps to 118 BPM which is BPM of deck B
I cannot see (have no idea yet) where I can see the master deck settings on VDJ.
I gues I do something wrong, however as a newbee I have no idea where to search where to get Deck A at the BPM of the track itself.
When I start on Deck A with same 3 other decks loaded
A 130 bpm
B 118 bpm
C 136 bpm
D 126 bpm
all other deck are behaving as desired: playing its own BPM
Noted also now that Deck A is always following the latest deck activated.
Where do I have to look for?
A 130 bpm
B 118 bpm
C 136 bpm
D 126 bpm
A 130 bpm
B 118 bpm
C 136 bpm
D 126 bpm
Posted Sun 05 Feb 23 @ 7:11 pm
Your description sound like auto sync on play (smart play) is enabled on one of the decks
Posted Mon 06 Feb 23 @ 3:51 am
AUTO SYNC ON PLAY is also 'off', moreover all auto settings are disabled.
it's really annoying as you might imagine...
anybody else?
anybody else?
Posted Mon 06 Feb 23 @ 5:02 am
anybody else?
anybody else?
Sync has been strange since my last update as well.
Posted Tue 07 Feb 23 @ 2:12 pm
