Is it possible to set up a filter folder to watch a certain directory on your computer and automagically add files that are added in there?
Posted Tue 27 Sep 22 @ 12:26 pm
no on the filter folder but
you could set a folder on your computer to a favorite and any time you look in there it will add the files it finds to the search DB if you have the auto option enabled they will still need to be analyzed though
Posted Tue 27 Sep 22 @ 12:30 pm
