When I am exporting my playlists in text format, VDJ will use the timestamp in format "hh:mm".
No I am converting my playlist for use in my MixCloud uploads, but I would also need seconds there ("hh:mm:ss") for a mora accurate track assignment.
Does anyone know if this is possible, and if yes, how?
Thanks in advance! - Patric aka DJ PepeWuhu
Posted Fri 02 Sep 22 @ 8:46 am
Easiest way is to enable recordWriteCueFile
Then vdj will write a .cue file while recording which can be used directly on mixcloud.
Posted Fri 02 Sep 22 @ 10:03 am
