Topic: hidtrace.exe - it's no work i'm nervous
selevoHome userMember since 2021
Posted Sun 28 Nov 21 @ 4:03 pm
Do you operate your device while running hidtrace ?
Also does it send regular report pages ?
What kind of device is it ?
Posted Mon 29 Nov 21 @ 1:20 pm
That's pretty tragic, I identified vendor by sight [sorted out using a logitech powerpoint remote for somebody yesterday]
vid 0x046D pid 0xC52F
Logitech, Inc.
Unifying Receiver
I don't think it sends HID as vdj can use it, but check your keyboard mapper if it inputs there [the clicker I worked on, sent keystroke data]
Posted Mon 29 Nov 21 @ 1:44 pm
Oh, good day!
this program not for all HIDdevice
i checked 4 deveces, 3 mouse and 1 wired keyboard (1 wired mouse and 2 wireless)
hidtrace only 1 device decoded a4tech combo device (mouse+keyboard)
But all this devices 'HID-device' in my sstem
Posted Mon 29 Nov 21 @ 5:46 pm
I believe hidtrace ignores keyboards & mice input, but can't say for certain.
Posted Mon 29 Nov 21 @ 5:56 pm
I wonder if the program will scan the data of cheap aliexpress mice like these ...?
http://ali.pub/654ob7
Posted Tue 30 Nov 21 @ 4:23 pm
The hidtrace is useful for HID devices that work as such in VirtualDJ and intended to assist creating definition files for HID controllers that will be detected in VirtualDJ. Since devices like keyboard, mouse etc are not considered HID devices for VirtualDJ, this application may not be useful if you need it for purposes outside VirtualDJ.
there are a few other applications out there to display data from any USB device (MIDI or HID) , such as USBLyzer
Posted Tue 30 Nov 21 @ 4:26 pm
