Hello all,
since the last update my VDJ does not run properly anymore. After about 15-20 min the program closes by itself. Reopening the program does not work anymore (opens for 1-2 sec. and closes afterwards). If I delete the cache folder I can use the program again with the above mentioned time, after that it crashes again. Also a repair or reinstallation could not fix the error. Does anyone have an idea what this could be due to or what else I could try?
Thanks in advance for your support.
Posted Fri 19 Nov 21 @ 9:38 pm
