Hi there,
for any reason when I switch from ModernEQ to STEMS the filter knob doesn't work anymore. When the mouse is over the knob in vdj it shows "COLOR FX", and therefore I've tried to change the mapping from "filter" to something similar to color fx, no success. How can I remap the filter knob to doing the common filter function? I have searched in the forum and it seems nobody has reported this, so probably I'm doing something wrong.
Thank you in advance!
Posted Fri 19 Nov 21 @ 7:23 am
Change the eq mode back to EZRemix, ModernEQ or Frequencies.
https://www.virtualdj.com/manuals/virtualdj/interface/mixer/audio.html#eqmode
'Stems' is intended to use 5 knobs, where the filter button controls the bass stem.
Posted Fri 19 Nov 21 @ 7:26 am
Thanks for answering!
Well, the thing is that the knob filter doesn't seem to work on this mode (hithat, vocal, kick work smooth). How could I map my filter knob to work as bass on STEMS mode?
Posted Fri 19 Nov 21 @ 8:27 am
