I have been using my VDJ21 with my Deonon MC4000 controller. I only have 5 knobs on each channel.
Gain, High, Mid , Low and now Vocal. In the past the Vocal knob was my Low Pass / High Pass filter.
Is there a way I can get that back? Can I create a keyboard button to switch that knob from Instrumental/Vocals to Low pass High pass?
Or can I assign the filter to another knob or button. Maybe the beats knob under both channel effects? ( Again definitely need help with the programming)
Lastly, I am a novice when it comes to customization of skins and controllers. Would any experts on this board please walk me through the commands and the process.
Thank you VERY MUCH!! Chris
Posted Sat 06 Nov 21 @ 1:55 pm
https://www.virtualdj.com/manuals/virtualdj/interface/mixer/audio.html
Number 8, switch to filter
Posted Sat 06 Nov 21 @ 2:21 pm
Thank you!!!!
However I forget to say I’m using the old vdj8 skin only because I like to have the three effects present.
Can I get that toggle on the old skin?
Or is there a way to get the three drop down effects on the new skin?
Thank you so much!!
I guess I should be using the new skin.
Thank you so much!!
Posted Sat 06 Nov 21 @ 5:11 pm
I think the pro skin has just about everything!!!
Sorry plus a few user custom items.
Can anyone suggest some additional items.
Again pardon my ignorance. I need to spend more time with VDJ21.
However the more time I do spend the more impressed I get!
Thanks!!!
Thanks!!!
Posted Sat 06 Nov 21 @ 5:26 pm
