I have 2 Keyboard map layouts, that I switch between on the fly when using Virtual DJ.
which have worked flawlessly up to build version 6613.
but since build 6646, it crashes virtual DJ, when I press the keys to switch between them.
so in the first keyboard map layout, I have the line.
<map value="CTRL+ALT+A" action="controller_mapping "KEYBOARD" "CustomKey2"" />
(which switches me to the second keyboard layout.)
and in the second keyboard map I have the line
<map value="CTRL+ALT+A" action="controller_mapping "KEYBOARD" "CustomKey1"" />
(which switches me back to the first keyboard layout).
So basically I press CTRL+ALT+A, to switch back and forth between them.
Any ideas / solutions, as to why it does not work from build 6646?
thanks
thanks
Posted Wed 20 Oct 21 @ 1:44 pm
Looks like there was indeed a change that broke this. Will be fixed in the next update.
Posted Wed 20 Oct 21 @ 1:53 pm
VirtualDj 8.5 b6677 crashes without a certain issues. It was normal before this update I don't really know what causes the crash. It happen to me like 4times while am on gig twice within 1 hour
Posted Mon 25 Oct 21 @ 11:46 pm
