Hey folks... new here... first time posting infact. I've used VDJ7 for years... and I used a sound FX plugin called fade... you hit the button, and it would simply fade out the song to silence. Can I do this in the new VDJ? I've found a pad that fades out with a filter effect, but I need to be able to do it without the filter... Is there anyone here able to offer some assistance, please?
Thanks
Lee
Thanks
Lee
Posted Tue 28 Sep 21 @ 5:33 pm
show the script
Posted Tue 28 Sep 21 @ 5:44 pm
Here is a script from the site to use on a custom button:
repeat_start_instant 'levelSweep' 10ms 101 & level & param_smaller 1% ? stop & repeat_stop 'levelSweep' & stop & repeat_start "WaitTimer" 100ms 1 & level 100% : level -1% : nothing
Posted Tue 28 Sep 21 @ 6:17 pm
Excellent!!!! :) Thank you so much!!! :)
Posted Tue 28 Sep 21 @ 7:29 pm
Does anyone know if it's possible to put this into a plugin effect, so I could have a button to trigger it for each deck? rather than just the active deck with the pad
Posted Tue 28 Sep 21 @ 8:53 pm
virtualfx does that if you have windows machine
Posted Tue 28 Sep 21 @ 9:08 pm
CLEAN THE SCRIPT
repeat_start levelSweep 10ms 101 & level -1% & level 0 ? repeat_stop levelSweep & stop & repeat_start WaitTimer 100ms 1 & level 100% :
THEN apply it to a specific deck if needed
can be one pad button per deck
deck 1 repeat_start levelSweep 10ms 101 & level -1% & level 0 ? repeat_stop levelSweep & stop & repeat_start WaitTimer 100ms 1 & level 100% :
deck 2 repeat_start levelSweep 10ms 101 & level -1% & level 0 ? repeat_stop levelSweep & stop & repeat_start WaitTimer 100ms 1 & level 100% :
sometime "/wiki/VDJScript Examples Database.html" have to be updated too ^^
Posted Tue 28 Sep 21 @ 11:41 pm
LOCODOG... What is virtualfx bud?
NICOTUX... What do u mean by clean the script?
I get the one button for each deck idea though.
Posted Wed 29 Sep 21 @ 4:00 pm
clean the script : there are things not needed anymore (old script)
virtualfx (aka DiY)is an addon by Locodog
https://virtualdj.com/forums/233818/addons/virtualFX.html
allows to create buttons and sliders for almost anything you can imagine and use them as a plugin
Posted Wed 29 Sep 21 @ 4:32 pm
