Disturbances (scratching and cracking) in the sound when playing via the Focusrite USB Asio driver. (Latency 1024) Also when playing via Focusrite USB Wasapi (Exclusive). When I reduce the latency, the interference turns into noise.
Wasapi (not Exclusive) works.
My digital-to-analog converter is a "focusrite scarlett 8i6 3rd gen".
When playing the files with foobar2000 I have the same problem. There are no problems when playing with JRiver or Presonus Studio One.
What could be the problem? I hope for a solution.
Many thanks in advance
Posted Mon 16 Aug 21 @ 12:33 pm
Solution: Ultralatenz turn on - YES! - Buffer-Size 1024 - it rocks ...
Posted Wed 18 Aug 21 @ 10:51 pm
