How can one test for the length of a loop?
param_equal `get_loop` 4 ? ACTION 1 : ACTION 2
would be my guess to test if the current or default loop is 4 beats, and it does not work.
Posted Sun 20 Jun 21 @ 10:19 am
          no backquotes needed with param_equal
param_equal get_loop 4 ? ACTION 1 : ACTION 2
Posted Sun 20 Jun 21 @ 1:53 pm
          @Nicotux
Thank you for awesome help
You ROCK !
You ROCK !
Posted Sun 20 Jun 21 @ 2:21 pm
