Topic: Virtual DJ8 Controller ?
So I was messing with "options". Ended up resetting defaults. Before, I had the knobs on controller as a default set. Eg: turn on controller, load VDJ8 and whatever the control eq's were set at the skin show the same postions.
I can't remember what option it was to allow that. Any Idea???
Posted Wed 12 May 21 @ 9:06 pm
search
takeovermode
you want instant
possible turn
resetEQ
to off as well
Posted Wed 12 May 21 @ 9:14 pm
The instant option works. but only when I touch the knobs on controller. I guess I can work with that. I just had some setting where I would run VDJ and the eqs would automatically set whatever the controller was set at.
Posted Wed 12 May 21 @ 9:25 pm
what controller?
Posted Wed 12 May 21 @ 9:26 pm
NS7 III
Posted Wed 12 May 21 @ 9:30 pm
can't think of how a setting would make a difference, booting the program and it calling refresh_controller "should" sync the skin to the controller.
I'm not doubting you, you have the device right there. I'm just working from what I've picked up over the years, this might be a dev question.
Posted Wed 12 May 21 @ 11:03 pm
TY locodog, I'll use your idea until I stumble across whatever I did before.
Posted Thu 13 May 21 @ 5:49 pm
