Hi I don’t know if anybody could help me on the situation, I am wanting to use my wireless mike set up with Virtual DJ on my mixed track pro three, so I plugged in my wireless mike unit to the right hand side of the mix track pro three mike input port, and I cannot find how to get the signal to go through mixed track pro three and Virtual DJ am I doing something wrong here
Posted Mon 15 Feb 21 @ 6:00 pm
The Microphone Input on the Mixtrack Pro 3 is directly routed to the master output of the controller and has nothing to do with Virtual DJ or any other DJ Software. all you need to do is plug in your wireless mic receiver into the mic input on the MTPRO3 and make sure is turned up and make sure that volume level(if the receiver has one) is turned up on the receiver for each microphone and it should work ;)
Posted Mon 15 Feb 21 @ 6:52 pm
