Sinds a week my Pioneer DDJ-SZ2 has the problem that when i start up VDJ b6240 the left player not connect. The player give the tekst Mute in de display where normaly Artist en Titel are seen. Tried to fix ix with older version, new driver installation Pioneer, new VDJ installation, different USB poorts but nothing helps.... If i turn the swits from channel 1 from USB to CD and back dan comes the player online en works normaal. Does anyone have a suggestion for me?
Greatings Peter van Dijk (Netherlands)
Posted Sun 03 Jan 21 @ 3:21 pm
If it says "MUTE" on deck, you probably have set the channel on the mixer to Line-In/Phono-In etc and not to PC (or the correct USB .. A vs B)
Mute just means that VirtualDJ is "muted" and that the channel on the mixer is getting sound from other source
But I guess you already noticed this. Should detect if its set to correct USB at start up....
Posted Sun 03 Jan 21 @ 3:24 pm
