Does such a thing exists?
Like I just add a song I want to start with, add some songs I want to play, and it generates me a list of matching songs for a complete set?
Posted Mon 21 Dec 20 @ 12:51 pm
You can start making a playlist, then play it back and use the song suggestions at the bottom to find songs that VDJ thinks will match.
You can drag those suggesions directly into the playlist then.
If you're looking for something like Spotify has where for every playlist it suggest a bunch of songs to add, VDJ doesn't have quite exactly that.
Posted Mon 21 Dec 20 @ 12:55 pm
I mean more like an application where I can make a playlist to tell my story.
Like I want to start with this song, add some songs, and it can look on my music library, deezer, beatport etc for matching songs
Posted Mon 21 Dec 20 @ 12:57 pm
sounds more like you want to let automix dj for you.
Posted Mon 21 Dec 20 @ 10:10 pm
No, its more when I make my playlist, (I select first song, piek songs and ending song, I now do it manually by selecting what I know and what fits in the set.) whenI put some songs on the list, I would like to know if a program exist that can advise me what to add. I'm always grabbing back to the songs I know, but I want to try new music in it.
Posted Tue 22 Dec 20 @ 8:38 am
you could try this
https://virtualdj.com/manuals/virtualdj/interface/database/geniusdj.html
Posted Tue 22 Dec 20 @ 10:25 am
My brain is not a supercomputer DJ hip-hop rap and pop mixshow
Posted Fri 16 Dec 22 @ 11:49 pm
My its possibil to script its over the genuiDj,
play song one, than auto insert the next song to the automix list and so on.
Onyl if this track exist on the drive or cloud.
Then search for the next track with genuiDj.
I think that will goes.
Ask Klaus Morgensen or LocoDog, they are the scripting superheros.
Posted Tue 20 Dec 22 @ 12:11 pm
