Hi
How do I specify leftdeck and rightdeck?
would like a controller LED to blink when a condition false.
will cause LED to blink when one of the volume faders is not at 100% (works)
I would like the controller LED to blink when BOTH the left AND right volume faders are NOT at 100%
PS
level 100% ? off : blink
leftdeck level 100% & rightdeck level 100% ? off : blink<< (is always false, blinking) NOT WORKING
PS
leftdeck level 100% ? off : blink<< (is also always false, blinking) NOT WORKING, so don't know how to specify left and right volume faders it seems.
Posted Mon 19 Oct 20 @ 10:53 pm
only blinks when both are not 100%
deck left level 1 ? off : deck right level 1 ? off : blink
and some related
only blink when both are 100%
not param_equal 'param_add "deck left level" "deck right level"' 2 ? off : blink
blink when one is not 100%
blink when one is 100%
deck left level 1 ? blink : deck right level 1 ? blink : off
blink when 1 is 100% lit when both are 100%
param_equal 'param_add "deck left level" "deck right level"' 2 ? on : deck left level 1 ? blink : deck right level 1 ? blink : off
and some related
Posted Mon 19 Oct 20 @ 11:19 pm
deck left level 100% ? deck right level 100% ? off : blink : blink
In other words, you use deck left or deck right to perform your queries. You can also use deck 1, deck 2, e.t.c.
Also...
When you do queries it's NOT advised to use "AND" logic because of the way VDJ Script is structured.
It's always best to nest multiple queries (IF's)
So, in a nutshell, with VirtualDJ you don't say
If apples=red AND bananas=yellow then make fruit salad else leave them on fridge
With VirtualDJ you say:
If apples=red then
---->if bananas=yellow then
---->---->make fruit salad else
---->leave them on fridge (apples are red but bananas are not yellow) else
leave them on fridge (apples are not red, we don't examine what color bananas are)
Posted Mon 19 Oct 20 @ 11:21 pm
Nicotux wrote :
and some related
I think someone must learn to walk before he can learn to run... :P
Those scripts are 'complex' even for advanced users! :)
Posted Mon 19 Oct 20 @ 11:26 pm
Big Thanks, Guys
So happy to learn from the Amazingly Talented DJs here in the Forum.
And I always welcome more info, then too little, as I learn VDJ Scripting.
Again you Guys ROCK . Thank you.!!
PS
Thank you PhantomDeejay for the TIP on structuring queries with VDJ Script.
Is there a limit to level of nesting allowed ?
PS
Posted Tue 20 Oct 20 @ 12:04 am
To follow up, to maybe help someone wishing to something related.
While these both WORK
Again Thanks PhantomDeejay & Nicotux !!
deck left level 1 ? off : deck right level 1 ? off : blink<<< Does NOT work (Bug? that it needs to be decimal)
deck left level 100% ? off : deck right level 100% ? off : blink
deck left level 1. ? off : deck right level 1. ? off : blink< While BOTH WORK Blinks when BOTH are NOT at 100% (the AND logic structure nesting)
deck left level 100% ? deck right level 100% ? off : blink : blink<<< BLINKS when either the Left or Right is NOT at 100% (The OR logic structure nesting)
Posted Tue 20 Oct 20 @ 12:47 am
There's no limit to the level of nesting. You can go as mad as you want.
Posted Tue 20 Oct 20 @ 12:54 am
just copy/paste
it is working well here both in pad & custom_button
Posted Tue 20 Oct 20 @ 1:03 am
Nicotux wrote :
just copy/paste
Its strange I can only get that amazing script above to work when I change the "1" (integer) >> "1." (decimal) or "100%" (percentage).
Cannot get it to work in a custom button or in a controller mapping... once I change the 1 to 1. or 100% it works perfectly for both the custom button and in mapping for the LED.
Don't know if its a bug. or ?
Again Much Thanks you for your help !
Let me know if there is anything I should test/check ?
CPU: AMD Ryzen 7 2700X Eight-Core Processor (3700 MHz)
Memory: 65487 MB
OS Version: Microsoft Windows 10 64-bit (Build 19041.572)
Graphics Card Vendor: NVIDIA Corporation
Graphics Card: GeForce GTX 1080 Ti/PCIe/SSE2
VDJ v8.5-64 b6106 w Default Pro Skin
Posted Tue 20 Oct 20 @ 4:14 am
interesting, strange script reaction that differ from one machine to another one :/
intel i5 2400s & nvidia 520m
or maybe due to ghost parameter...
Clearly a bug
but tracking it... would be fine to see if level & param_cast trunc returns 1 or 0 in such a case
reveal a set of bugs here: (known and already reported bugs - one with parameter passing and one with casting and one with relative)
"level & debug" as "well as level && debug" always return "no param" (or previous param if in a chain): there is no return value BUG
"get_level" returns the signal level thus not related
"level & cast_float & debug" gives the correct value GOOD so that the value returns but not as a parameter
"level & param_cast trunc & debug gives the decimal value !!! BUG
"level & param_cast int_trunc & debug gives the decimal value !!! BUG
"level & param_cast trunc & param_cast float & debug gives the decimal value !!! BUG
"level & param_cast int_trunc & param_cast float & debug gives 1.0 or 0.0 as wanted GOOD
"get_constant 10 & param_cast float & level & param_cast trunc & debug" gives bool: 0 >>> why? level takes the param and set level and returns FALSE ?
"get_constant 0 & param_cast float & level & param_cast trunc & debug" gives bool: 1 >>> why? level takes the param and set level and returns OK ? (range [0..1] returns 1; range ]1..[ returns 0)
... negative values .... ^^ TYPE: value (relative)
+ prepend values .... ^^ TYPE: value (relative)
Clearly a bug
Posted Tue 20 Oct 20 @ 5:47 am
Let me know if there is a script I can run to test...
Again thank you for your help, and I am happy that it works, big smile !
and yes strange.
Posted Tue 20 Oct 20 @ 10:36 am
