Hello there,
I was mapping my NI Kontrol D2 (not supported officially by VDJ) once I was done mapping I connected to my laptop and everything worked just fine, until I connected the Pioneer DJM 900 nxs. don't know why or how but my D2's disappeared from my devices and stop working, the same happened if I connected my cdj’s 2000 nxs, so I started to try different connections and in all the cases the problem was when I connected the cdj’s with/or the djm only, because I have and DDJ-XP2 and it didn’t happen
These are my test and combinations
1 XP2 | 2 D2's
XP2 | DJM900nxs | 2 D2's (missing but connected to my mac)
Rane 72 | Kontrol X1MK2 | Kontrol F1
Rane 72 | DJM900nxs | Kontrol X1MK2 | Kontrol F1 (Compared with the 3rd image, when I connect the djm VDJ remove the X1 and the F1 but as inputs)
I used these combinations in other Dj softwares with no problem at all for ex. SDJ which does not officially support any NI controller
Thank you in advance for any help or workaround
1 XP2 | 2 D2's
Posted Mon 27 Apr 20 @ 12:29 am
Are you on Mac or Windows ?
Can you share the first lines of your custom definition (the <device ...> part) ?
And because there is a strong chance all these entries in the Device List may come from your "incorrect" definition, if you can provide the following too...
- Open VirtualDj, goto Settings and set CreateMidiLog to Yes
- Restart VirtualDJ and post here the content of the Log Report.txt you will find in /Documents/VirtualDJ folder.
Posted Mon 27 Apr 20 @ 7:20 pm
Hello DjDad
I'm using a mac (actually I tried in 2 laptops both macs)
"Can you share the first lines of your custom definition (the <device ...> part) ?"
I don't have a custom definition I'm only using it as midi, I going back to VDJ after 10 years I'm rusty with vdj scripts, etc. I'm trying to go full VDJ only, but I would like to use all my midi's ;)
I did some new test in the second mac, clean OS install and VDJ I have attached an image from the test maybe are helpful and this is the log (I did some plug and unplug) thank you in advance
MIDI LOG
--- 2020/04/27 - 18:21 (5680)
[18:21] USB MIDI device: vid:0x05AC pid:0x8242 usbName:IR Receiver vendorName:Apple Computer, Inc. serialNumber:
[18:21] USB MIDI device: vid:0x05AC pid:0x0236 usbName:Apple Internal Keyboard / Trackpad vendorName:Apple, Inc. serialNumber:
[18:21] USB MIDI device: vid:0x17CC pid:0x1220 usbName:Traktor Kontrol X1 MK2 vendorName:Native Instruments serialNumber:961C5041
[18:21] USB MIDI device: vid:0x17CC pid:0x1403 usbName:Traktor Kontrol D2 Hub vendorName:Native Instruments serialNumber:4C84B288
[18:21] USB MIDI device: vid:0x17CC pid:0x1400 usbName:Traktor Kontrol D2 vendorName:Native Instruments serialNumber:4C84B288
[18:21] USB MIDI device: vid:0x17CC pid:0x1403 usbName:Traktor Kontrol D2 Hub vendorName:Native Instruments serialNumber:5DD97ED5
[18:21] USB MIDI device: vid:0x17CC pid:0x1400 usbName:Traktor Kontrol D2 vendorName:Native Instruments serialNumber:5DD97ED5
[18:21] USB MIDI device: vid:0x2B73 pid:0x0035 usbName:DDJ-XP2 vendorName:Pioneer DJ Corporation serialNumber:000000000001
[18:21] Midi in device detected: \\?\usb#VID_2B73&PID_0035/605233152 (port:)
[18:21] Midi device: name:Traktor Kontrol D2 - 1 Input manufacturer: model:
[18:21] Midi in device detected: Traktor Kontrol D2 - 1 Input (port:Traktor Kontrol D2 - 1 Input)
[18:21] Midi device: name:Traktor Kontrol D2 - 2 Input manufacturer: model:
[18:21] Midi in device detected: Traktor Kontrol D2 - 2 Input (port:Traktor Kontrol D2 - 2 Input)
[18:21] Midi device: name:Traktor Kontrol X1 MK2 - 1 Input manufacturer: model:
[18:21] Midi in device detected: Traktor Kontrol X1 MK2 - 1 Input (port:Traktor Kontrol X1 MK2 - 1 Input)
[18:21] Midi out device detected: \\?\usb#VID_2B73&PID_0035/605233152 (port:)
[18:21] Midi device: name:Traktor Kontrol D2 - 1 Output manufacturer: model:
[18:21] Midi out device detected: Traktor Kontrol D2 - 1 Output (port:Traktor Kontrol D2 - 1 Output)
[18:21] Midi device: name:Traktor Kontrol D2 - 2 Output manufacturer: model:
[18:21] Midi out device detected: Traktor Kontrol D2 - 2 Output (port:Traktor Kontrol D2 - 2 Output)
[18:21] Midi device: name:Traktor Kontrol X1 MK2 - 1 Output manufacturer: model:
[18:21] Midi out device detected: Traktor Kontrol X1 MK2 - 1 Output (port:Traktor Kontrol X1 MK2 - 1 Output)
--- 2020/04/27 - 18:22 (5680)
[18:22] USB MIDI device: vid:0x05AC pid:0x8242 usbName:IR Receiver vendorName:Apple Computer, Inc. serialNumber:
[18:22] USB MIDI device: vid:0x05AC pid:0x0236 usbName:Apple Internal Keyboard / Trackpad vendorName:Apple, Inc. serialNumber:
[18:22] USB MIDI device: vid:0x17CC pid:0x1220 usbName:Traktor Kontrol X1 MK2 vendorName:Native Instruments serialNumber:961C5041
[18:22] USB MIDI device: vid:0x17CC pid:0x1403 usbName:Traktor Kontrol D2 Hub vendorName:Native Instruments serialNumber:4C84B288
[18:22] USB MIDI device: vid:0x17CC pid:0x1400 usbName:Traktor Kontrol D2 vendorName:Native Instruments serialNumber:4C84B288
[18:22] USB MIDI device: vid:0x17CC pid:0x1403 usbName:Traktor Kontrol D2 Hub vendorName:Native Instruments serialNumber:5DD97ED5
[18:22] USB MIDI device: vid:0x17CC pid:0x1400 usbName:Traktor Kontrol D2 vendorName:Native Instruments serialNumber:5DD97ED5
[18:22] USB MIDI device: vid:0x2B73 pid:0x0035 usbName:DDJ-XP2 vendorName:Pioneer DJ Corporation serialNumber:000000000001
[18:22] USB MIDI device: vid:0x08E4 pid:0x0158 usbName:DJM-900nexus vendorName:Pioneer Corporation serialNumber:
[18:22] Audio device found: name:Built-in Microphone hardwareID:"39"
[18:22] Audio device found: name:Built-in Input hardwareID:"57"
[18:22] Audio device found: name:Built-in Output hardwareID:"49"
[18:22] Audio device found: name:DJM-900nexus vid="0x08E4" pid="0x0158" hardwareID:"66"
[18:22] Midi in device detected: \\?\usb#VID_08E4&PID_0158/641728512 (port:)
[18:22] Midi in device detected: \\?\usb#VID_2B73&PID_0035/605233152 (port:)
[18:22] Midi in device detected: \\?\usb#VID_08E4&PID_0158/641728512 (port:\\?\usb#VID_08E4&PID_0158/641728512)
[18:22] Midi out device detected: \\?\usb#VID_2B73&PID_0035/605233152 (port:)
[18:22] Midi out device detected: \\?\usb#VID_08E4&PID_0158/641728512 (port:\\?\usb#VID_08E4&PID_0158/641728512)
[18:22] MIDI Device Identifying: \\?\usb#VID_08E4&PID_0158/641728512 (in:0 out:1) (name: DJM-900nexus)
[18:22] MIDI Device Identified by PID/VID: \\?\usb#VID_08E4&PID_0158/641728512 : Pioneer DJM-900NXS
[18:22] Assigned Keyboard, type:0, index:1
[18:22] Assigned Pioneer DJM-900NXS, type:1, index:1
[18:22] MIDI Device Identifying: \\?\usb#VID_2B73&PID_0035/605233152 (in:1 out:0) (name: DDJ-XP2)
[18:22] MIDI Device Identified by PID/VID: \\?\usb#VID_2B73&PID_0035/605233152 : Pioneer DDJ-XP2
[18:22] Assigned Pioneer DDJ-XP2, type:4, index:1
[18:22] MIDI Device Identifying: \\?\usb#VID_08E4&PID_0158/641728512 (in:2 out:2) (name: Traktor Kontrol D2 - 1 Input)
[18:22] MIDI Device Identifying: \\?\usb#VID_08E4&PID_0158/641728512 (in:3 out:3) (name: Traktor Kontrol D2 - 2 Input)
[18:22] MIDI Device Identifying: \\?\usb#VID_08E4&PID_0158/641728512 (in:4 out:-1) (name: Traktor Kontrol X1 MK2 - 1 Input)
[18:22] HID Device found, looking for definition. \\?\hid#VID_05AC&PID_8242/72351744
[18:22] HID Device found, looking for definition. \\?\hid#VID_05AC&PID_0236/73400320
[18:22] HID Device found, looking for definition. \\?\hid#VID_17CC&PID_1220/639631360
[18:22] Found definition for Traktor Kontrol X1 MK2
[18:22] HID Device found, looking for definition. \\?\hid#VID_17CC&PID_1400/605093888
[18:22] HID Device found, looking for definition. \\?\hid#VID_17CC&PID_1400/605229056
[18:22] HID Device found, looking for definition. \\?\hid#VID_2B73&PID_0035/605233152
[18:22] HID Device found, looking for definition. \\?\hid#VID_0000&PID_0000/0
[18:22] HID Device found, looking for definition. \\?\hid#VID_05AC&PID_030D/1796020640
[18:22] Midi device: name:Traktor Kontrol D2 - 1 Input manufacturer: model:
[18:22] Midi in device detected: Traktor Kontrol D2 - 1 Input (port:Traktor Kontrol D2 - 1 Input)
[18:22] Midi device: name:Traktor Kontrol D2 - 2 Input manufacturer: model:
[18:22] Midi in device detected: Traktor Kontrol D2 - 2 Input (port:Traktor Kontrol D2 - 2 Input)
[18:22] Midi device: name:Traktor Kontrol X1 MK2 - 1 Input manufacturer: model:
[18:22] Midi in device detected: Traktor Kontrol X1 MK2 - 1 Input (port:Traktor Kontrol X1 MK2 - 1 Input)
[18:22] Midi device: name:Traktor Kontrol D2 - 1 Output manufacturer: model:
[18:22] Midi out device detected: Traktor Kontrol D2 - 1 Output (port:Traktor Kontrol D2 - 1 Output)
[18:22] Midi device: name:Traktor Kontrol D2 - 2 Output manufacturer: model:
[18:22] Midi out device detected: Traktor Kontrol D2 - 2 Output (port:Traktor Kontrol D2 - 2 Output)
[18:22] Midi device: name:Traktor Kontrol X1 MK2 - 1 Output manufacturer: model:
[18:22] Midi out device detected: Traktor Kontrol X1 MK2 - 1 Output (port:Traktor Kontrol X1 MK2 - 1 Output)
[18:22] MIDI Device Identifying: Traktor Kontrol D2 - 1 Input (in:1 out:-1) (name: Traktor Kontrol D2 - 1 Input)
[18:22] MIDI Device Identified by general midi: Traktor Kontrol D2 - 1 Input
[18:22] MIDI Device Identifying: Traktor Kontrol D2 - 2 Input (in:2 out:-1) (name: Traktor Kontrol D2 - 2 Input)
[18:22] MIDI Device Identified by general midi: Traktor Kontrol D2 - 2 Input
[18:22] MIDI Device Identifying: Traktor Kontrol X1 MK2 - 1 Input (in:3 out:-1) (name: Traktor Kontrol X1 MK2 - 1 Input)
[18:22] MIDI Device Identified by general midi: Traktor Kontrol X1 MK2 - 1 Input
[18:22] MIDI Device Identifying: Traktor Kontrol D2 - 1 Output (in:-1 out:1) (name: Traktor Kontrol D2 - 1 Output)
[18:22] MIDI Device Not Identified: Traktor Kontrol D2 - 1 Output
[18:22] MIDI Device Identifying: Traktor Kontrol D2 - 2 Output (in:-1 out:2) (name: Traktor Kontrol D2 - 2 Output)
[18:22] MIDI Device Not Identified: Traktor Kontrol D2 - 2 Output
[18:22] MIDI Device Identifying: Traktor Kontrol X1 MK2 - 1 Output (in:-1 out:3) (name: Traktor Kontrol X1 MK2 - 1 Output)
[18:22] MIDI Device Not Identified: Traktor Kontrol X1 MK2 - 1 Output
[18:22] Midi out device reconnected: Traktor Kontrol D2 - 1 Output
[18:22] Midi out device reconnected: Traktor Kontrol D2 - 2 Output
[18:22] Midi out device reconnected: Traktor Kontrol X1 MK2 - 1 Output
[18:22] MIDI Device Identifying: \\?\usb#VID_2B73&PID_0035/605233152 (in:0 out:0) (name: DDJ-XP2)
--- 2020/04/27 - 18:24 (5680)
[18:24] USB MIDI device: vid:0x05AC pid:0x8242 usbName:IR Receiver vendorName:Apple Computer, Inc. serialNumber:
[18:24] USB MIDI device: vid:0x05AC pid:0x0236 usbName:Apple Internal Keyboard / Trackpad vendorName:Apple, Inc. serialNumber:
[18:24] USB MIDI device: vid:0x17CC pid:0x1220 usbName:Traktor Kontrol X1 MK2 vendorName:Native Instruments serialNumber:961C5041
[18:24] USB MIDI device: vid:0x17CC pid:0x1403 usbName:Traktor Kontrol D2 Hub vendorName:Native Instruments serialNumber:4C84B288
[18:24] USB MIDI device: vid:0x17CC pid:0x1400 usbName:Traktor Kontrol D2 vendorName:Native Instruments serialNumber:4C84B288
[18:24] USB MIDI device: vid:0x17CC pid:0x1403 usbName:Traktor Kontrol D2 Hub vendorName:Native Instruments serialNumber:5DD97ED5
[18:24] USB MIDI device: vid:0x17CC pid:0x1400 usbName:Traktor Kontrol D2 vendorName:Native Instruments serialNumber:5DD97ED5
[18:24] USB MIDI device: vid:0x2B73 pid:0x0035 usbName:DDJ-XP2 vendorName:Pioneer DJ Corporation serialNumber:000000000001
[18:24] Audio device found: name:Built-in Microphone hardwareID:"39"
[18:24] Audio device found: name:Built-in Input hardwareID:"57"
[18:24] Audio device found: name:Built-in Output hardwareID:"49"
[18:24] Midi in device detected: \\?\usb#VID_2B73&PID_0035/605233152 (port:)
[18:24] Midi device: name:Traktor Kontrol D2 - 1 Input manufacturer: model:
[18:24] Midi in device detected: Traktor Kontrol D2 - 1 Input (port:Traktor Kontrol D2 - 1 Input)
[18:24] Midi device: name:Traktor Kontrol D2 - 2 Input manufacturer: model:
[18:24] Midi in device detected: Traktor Kontrol D2 - 2 Input (port:Traktor Kontrol D2 - 2 Input)
[18:24] Midi device: name:Traktor Kontrol X1 MK2 - 1 Input manufacturer: model:
[18:24] Midi in device detected: Traktor Kontrol X1 MK2 - 1 Input (port:Traktor Kontrol X1 MK2 - 1 Input)
[18:24] Midi out device detected: \\?\usb#VID_2B73&PID_0035/605233152 (port:)
[18:24] Midi device: name:Traktor Kontrol D2 - 1 Output manufacturer: model:
[18:24] Midi out device detected: Traktor Kontrol D2 - 1 Output (port:Traktor Kontrol D2 - 1 Output)
[18:24] Midi device: name:Traktor Kontrol D2 - 2 Output manufacturer: model:
[18:24] Midi out device detected: Traktor Kontrol D2 - 2 Output (port:Traktor Kontrol D2 - 2 Output)
[18:24] Midi device: name:Traktor Kontrol X1 MK2 - 1 Output manufacturer: model:
[18:24] Midi out device detected: Traktor Kontrol X1 MK2 - 1 Output (port:Traktor Kontrol X1 MK2 - 1 Output)
[18:24] MIDI Device Identifying: \\?\usb#VID_2B73&PID_0035/605233152 (in:0 out:0) (name: DDJ-XP2)
[18:24] MIDI Device Identified by PID/VID: \\?\usb#VID_2B73&PID_0035/605233152 : Pioneer DDJ-XP2
[18:24] Assigned Keyboard, type:0, index:1
[18:24] Assigned Pioneer DDJ-XP2, type:4, index:1
[18:24] MIDI Device Identifying: Traktor Kontrol D2 - 1 Input (in:1 out:-1) (name: Traktor Kontrol D2 - 1 Input)
[18:24] MIDI Device Identified by general midi: Traktor Kontrol D2 - 1 Input
[18:24] MIDI Device Identifying: Traktor Kontrol D2 - 2 Input (in:2 out:-1) (name: Traktor Kontrol D2 - 2 Input)
[18:24] MIDI Device Identified by general midi: Traktor Kontrol D2 - 2 Input
[18:24] MIDI Device Identifying: Traktor Kontrol X1 MK2 - 1 Input (in:3 out:-1) (name: Traktor Kontrol X1 MK2 - 1 Input)
[18:24] MIDI Device Identified by general midi: Traktor Kontrol X1 MK2 - 1 Input
[18:24] MIDI Device Identifying: Traktor Kontrol D2 - 1 Output (in:-1 out:1) (name: Traktor Kontrol D2 - 1 Output)
[18:24] MIDI Device Not Identified: Traktor Kontrol D2 - 1 Output
[18:24] MIDI Device Identifying: Traktor Kontrol D2 - 2 Output (in:-1 out:2) (name: Traktor Kontrol D2 - 2 Output)
[18:24] MIDI Device Not Identified: Traktor Kontrol D2 - 2 Output
[18:24] MIDI Device Identifying: Traktor Kontrol X1 MK2 - 1 Output (in:-1 out:3) (name: Traktor Kontrol X1 MK2 - 1 Output)
[18:24] MIDI Device Not Identified: Traktor Kontrol X1 MK2 - 1 Output
[18:24] HID Device found, looking for definition. \\?\hid#VID_05AC&PID_8242/72351744
[18:24] HID Device found, looking for definition. \\?\hid#VID_05AC&PID_0236/73400320
[18:24] HID Device found, looking for definition. \\?\hid#VID_17CC&PID_1220/639631360
[18:24] Found definition for Traktor Kontrol X1 MK2
[18:24] HID Device found, looking for definition. \\?\hid#VID_17CC&PID_1400/605093888
[18:24] HID Device found, looking for definition. \\?\hid#VID_17CC&PID_1400/605229056
[18:24] HID Device found, looking for definition. \\?\hid#VID_2B73&PID_0035/605233152
[18:24] HID Device found, looking for definition. \\?\hid#VID_0000&PID_0000/0
[18:24] HID Device found, looking for definition. \\?\hid#VID_05AC&PID_030D/1796020640
[18:24] Midi out device reconnected: Traktor Kontrol D2 - 1 Output
[18:24] Midi out device reconnected: Traktor Kontrol D2 - 2 Output
[18:24] Midi out device reconnected: Traktor Kontrol X1 MK2 - 1 Output
[18:24] USB MIDI device: vid:0x08E4 pid:0x0158 usbName:DJM-900nexus vendorName:Pioneer Corporation serialNumber:
[18:24] Midi in device detected: \\?\usb#VID_08E4&PID_0158/641728512 (port:)
[18:24] Midi in device detected: \\?\usb#VID_08E4&PID_0158/641728512 (port:\\?\usb#VID_08E4&PID_0158/641728512)
[18:24] Midi out device detected: \\?\usb#VID_08E4&PID_0158/641728512 (port:\\?\usb#VID_08E4&PID_0158/641728512)
[18:24] MIDI Device Identifying: \\?\usb#VID_08E4&PID_0158/641728512 (in:0 out:1) (name: DJM-900nexus)
[18:24] MIDI Device Identified by PID/VID: \\?\usb#VID_08E4&PID_0158/641728512 : Pioneer DJM-900NXS
[18:24] Assigned Pioneer DJM-900NXS, type:1, index:1
[18:24] MIDI Device Identifying: \\?\usb#VID_08E4&PID_0158/641728512 (in:2 out:2) (name: Traktor Kontrol D2 - 1 Input)
[18:24] MIDI Device Identifying: \\?\usb#VID_08E4&PID_0158/641728512 (in:3 out:3) (name: Traktor Kontrol D2 - 2 Input)
[18:24] MIDI Device Identifying: \\?\usb#VID_08E4&PID_0158/641728512 (in:4 out:-1) (name: Traktor Kontrol X1 MK2 - 1 Input)
[18:24] Audio device found: name:DJM-900nexus vid="0x08E4" pid="0x0158" hardwareID:"66"
MIDI LOG
Posted Mon 27 Apr 20 @ 10:33 pm
you say "the captures are made with the 3 programs open at the same time"..
so you had all 3 opened at the same time ?
You get the same results if only VDJ is opened ?
Posted Tue 28 Apr 20 @ 2:27 pm
Yes, first I tried with only VDJ open (same result) after that I tried opening the other 2 with VDJ open and also tried opening in different order to see if I get different results, thank you
quote=djdad]you say "the captures are made with the 3 programs open at the same time"..
You get the same results if only VDJ is opened ?[/quote]
Posted Tue 28 Apr 20 @ 4:16 pm
I separate the logs, thank you
Log Report - only NI D2
--- 2020/04/29 - 10:12 (5680)
[10:12] USB MIDI device: vid:0x05AC pid:0x8242 usbName:IR Receiver vendorName:Apple Computer, Inc. serialNumber:
[10:12] USB MIDI device: vid:0x05AC pid:0x0236 usbName:Apple Internal Keyboard / Trackpad vendorName:Apple, Inc. serialNumber:
[10:12] USB MIDI device: vid:0x17CC pid:0x1403 usbName:Traktor Kontrol D2 Hub vendorName:Native Instruments serialNumber:4C84B288
[10:12] USB MIDI device: vid:0x17CC pid:0x1400 usbName:Traktor Kontrol D2 vendorName:Native Instruments serialNumber:4C84B288
[10:12] USB MIDI device: vid:0x17CC pid:0x1403 usbName:Traktor Kontrol D2 Hub vendorName:Native Instruments serialNumber:5DD97ED5
[10:12] USB MIDI device: vid:0x17CC pid:0x1400 usbName:Traktor Kontrol D2 vendorName:Native Instruments serialNumber:5DD97ED5
[10:12] Audio device found: name:Built-in Microphone hardwareID:"39"
[10:12] Audio device found: name:Built-in Input hardwareID:"57"
[10:12] Audio device found: name:Built-in Output hardwareID:"49"
[10:12] Midi device: name:Traktor Kontrol D2 - 2 Input manufacturer: model:
[10:12] Midi in device detected: Traktor Kontrol D2 - 2 Input (port:Traktor Kontrol D2 - 2 Input)
[10:12] Midi device: name:Traktor Kontrol D2 - 1 Input manufacturer: model:
[10:12] Midi in device detected: Traktor Kontrol D2 - 1 Input (port:Traktor Kontrol D2 - 1 Input)
[10:12] Midi device: name:Traktor Kontrol D2 - 2 Output manufacturer: model:
[10:12] Midi out device detected: Traktor Kontrol D2 - 2 Output (port:Traktor Kontrol D2 - 2 Output)
[10:12] Midi device: name:Traktor Kontrol D2 - 1 Output manufacturer: model:
[10:12] Midi out device detected: Traktor Kontrol D2 - 1 Output (port:Traktor Kontrol D2 - 1 Output)
[10:12] MIDI Device Identifying: Traktor Kontrol D2 - 2 Input (in:0 out:-1) (name: Traktor Kontrol D2 - 2 Input)
[10:12] MIDI Device Identified by general midi: Traktor Kontrol D2 - 2 Input
[10:12] MIDI Device Identifying: Traktor Kontrol D2 - 1 Input (in:1 out:-1) (name: Traktor Kontrol D2 - 1 Input)
[10:12] MIDI Device Identified by general midi: Traktor Kontrol D2 - 1 Input
[10:12] MIDI Device Identifying: Traktor Kontrol D2 - 2 Output (in:-1 out:0) (name: Traktor Kontrol D2 - 2 Output)
[10:12] MIDI Device Not Identified: Traktor Kontrol D2 - 2 Output
[10:12] MIDI Device Identifying: Traktor Kontrol D2 - 1 Output (in:-1 out:1) (name: Traktor Kontrol D2 - 1 Output)
[10:12] MIDI Device Not Identified: Traktor Kontrol D2 - 1 Output
[10:12] HID Device found, looking for definition. \\?\hid#VID_05AC&PID_8242/72351744
[10:12] HID Device found, looking for definition. \\?\hid#VID_05AC&PID_0236/73400320
[10:12] HID Device found, looking for definition. \\?\hid#VID_17CC&PID_1400/605093888
[10:12] HID Device found, looking for definition. \\?\hid#VID_17CC&PID_1400/605229056
[10:12] HID Device found, looking for definition. \\?\hid#VID_0000&PID_0000/0
[10:12] Assigned Keyboard, type:0, index:1
[10:12] Midi out device reconnected: Traktor Kontrol D2 - 2 Output
[10:12] Midi out device reconnected: Traktor Kontrol D2 - 1 Output
Log Report - ONLY DJM 900
--- 2020/04/29 - 10:14 (5680)
[10:14] USB MIDI device: vid:0x05AC pid:0x8242 usbName:IR Receiver vendorName:Apple Computer, Inc. serialNumber:
[10:14] USB MIDI device: vid:0x05AC pid:0x0236 usbName:Apple Internal Keyboard / Trackpad vendorName:Apple, Inc. serialNumber:
[10:14] USB MIDI device: vid:0x08E4 pid:0x0158 usbName:DJM-900nexus vendorName:Pioneer Corporation serialNumber:
[10:14] Audio device found: name:Built-in Microphone hardwareID:"39"
[10:14] Audio device found: name:Built-in Input hardwareID:"57"
[10:14] Audio device found: name:Built-in Output hardwareID:"49"
[10:14] Audio device found: name:DJM-900nexus vid="0x08E4" pid="0x0158" hardwareID:"66"
[10:14] Midi in device detected: \\?\usb#VID_08E4&PID_0158/605028352 (port:)
[10:14] MIDI Device Identifying: \\?\usb#VID_08E4&PID_0158/605028352 (in:0 out:-1) (name: DJM-900nexus)
[10:14] MIDI Device Identified by PID/VID: \\?\usb#VID_08E4&PID_0158/605028352 : Pioneer DJM-900NXS
[10:14] Assigned Keyboard, type:0, index:1
[10:14] Assigned Pioneer DJM-900NXS, type:1, index:1
[10:14] HID Device found, looking for definition. \\?\hid#VID_05AC&PID_8242/72351744
[10:14] HID Device found, looking for definition. \\?\hid#VID_05AC&PID_0236/73400320
[10:14] HID Device found, looking for definition. \\?\hid#VID_0000&PID_0000/0
Log Report - DJM 900nxs + CDJ 2000nxs
[10:14] USB MIDI device: vid:0x08E4 pid:0x0162 usbName:PIONEER CDJ-2000nexus vendorName:PIONEER Corporation. serialNumber:
[10:14] Audio device found: name:PIONEER CDJ-2000nexus vid="0x08E4" pid="0x0162" hardwareID:"69"
[10:14] Midi in device detected: \\?\usb#VID_08E4&PID_0162/102760448 (port:)
[10:14] MIDI Device Identifying: \\?\usb#VID_08E4&PID_0162/102760448 (in:1 out:-1) (name: PIONEER CDJ-2000nexus)
[10:14] MIDI Device Identified by PID/VID: \\?\usb#VID_08E4&PID_0162/102760448 : Pioneer CDJ-2000nexus
[10:14] HID Device found, looking for definition. \\?\hid#VID_08E4&PID_0162/102760448
[10:14] Found definition for Pioneer CDJ-2000nexus
[10:14] Assigned Pioneer CDJ-2000nexus, type:2, index:1
[10:15] USB MIDI device: vid:0x05AC pid:0x8242 usbName:IR Receiver vendorName:Apple Computer, Inc. serialNumber:
[10:15] USB MIDI device: vid:0x05AC pid:0x0236 usbName:Apple Internal Keyboard / Trackpad vendorName:Apple, Inc. serialNumber:
[10:15] USB MIDI device: vid:0x08E4 pid:0x0158 usbName:DJM-900nexus vendorName:Pioneer Corporation serialNumber:
[10:15] USB MIDI device: vid:0x08E4 pid:0x0162 usbName:PIONEER CDJ-2000nexus vendorName:PIONEER Corporation. serialNumber:
[10:15] Midi in device detected: \\?\usb#VID_08E4&PID_0158/605028352 (port:)
[10:15] Midi in device detected: \\?\usb#VID_08E4&PID_0162/102760448 (port:)
DJM 900nxs + CDJ 2000nxs + NI D2
--- 2020/04/29 - 10:15 (5680)
[10:15] USB MIDI device: vid:0x17CC pid:0x1403 usbName:Traktor Kontrol D2 Hub vendorName:Native Instruments serialNumber:4C84B288
[10:15] USB MIDI device: vid:0x17CC pid:0x1400 usbName:Traktor Kontrol D2 vendorName:Native Instruments serialNumber:4C84B288
[10:15] Audio device found: name:Built-in Microphone hardwareID:"39"
[10:15] Audio device found: name:Built-in Input hardwareID:"57"
[10:15] Audio device found: name:Built-in Output hardwareID:"49"
[10:15] Audio device found: name:PIONEER CDJ-2000nexus vid="0x08E4" pid="0x0162" hardwareID:"69"
[10:15] Audio device found: name:DJM-900nexus vid="0x08E4" pid="0x0158" hardwareID:"66"
[10:15] Midi in device detected: \\?\usb#VID_08E4&PID_0162/639762432 (port:)
[10:15] Midi in device detected: \\?\usb#VID_08E4&PID_0158/605028352 (port:\\?\usb#VID_08E4&PID_0158/605028352)
[10:15] Midi out device detected: \\?\usb#VID_08E4&PID_0158/605028352 (port:\\?\usb#VID_08E4&PID_0158/605028352)
[10:15] MIDI Device Identifying: \\?\usb#VID_08E4&PID_0158/605028352 (in:0 out:0) (name: DJM-900nexus)
[10:15] MIDI Device Identified by PID/VID: \\?\usb#VID_08E4&PID_0158/605028352 : Pioneer DJM-900NXS
[10:15] Assigned Keyboard, type:0, index:1
[10:15] Assigned Pioneer DJM-900NXS, type:1, index:1
[10:15] MIDI Device Identifying: \\?\usb#VID_08E4&PID_0162/639762432 (in:1 out:-1) (name: PIONEER CDJ-2000nexus)
[10:15] MIDI Device Identified by PID/VID: \\?\usb#VID_08E4&PID_0162/639762432 : Pioneer CDJ-2000nexus
[10:15] MIDI Device Identifying: \\?\usb#VID_08E4&PID_0158/605028352 (in:2 out:-1) (name: Traktor Kontrol D2 - 1 Input)
[10:15] HID Device found, looking for definition. \\?\hid#VID_05AC&PID_8242/72351744
[10:15] HID Device found, looking for definition. \\?\hid#VID_05AC&PID_0236/73400320
[10:15] HID Device found, looking for definition. \\?\hid#VID_08E4&PID_0162/639762432
[10:15] Found definition for Pioneer CDJ-2000nexus
[10:15] HID Device found, looking for definition. \\?\hid#VID_17CC&PID_1400/639696896
[10:15] HID Device found, looking for definition. \\?\hid#VID_0000&PID_0000/0
[10:15] Assigned Pioneer CDJ-2000nexus, type:2, index:1
DJM 900nxs + NI D2
--- 2020/04/29 - 10:19 (5680)
[10:19] USB MIDI device: vid:0x05AC pid:0x8242 usbName:IR Receiver vendorName:Apple Computer, Inc. serialNumber:
[10:19] USB MIDI device: vid:0x05AC pid:0x0236 usbName:Apple Internal Keyboard / Trackpad vendorName:Apple, Inc. serialNumber:
[10:19] USB MIDI device: vid:0x08E4 pid:0x0158 usbName:DJM-900nexus vendorName:Pioneer Corporation serialNumber:
[10:19] USB MIDI device: vid:0x17CC pid:0x1403 usbName:Traktor Kontrol D2 Hub vendorName:Native Instruments serialNumber:4C84B288
[10:19] USB MIDI device: vid:0x17CC pid:0x1400 usbName:Traktor Kontrol D2 vendorName:Native Instruments serialNumber:4C84B288
[10:19] Audio device found: name:Built-in Microphone hardwareID:"39"
[10:19] Audio device found: name:Built-in Input hardwareID:"57"
[10:19] Audio device found: name:Built-in Output hardwareID:"49"
[10:19] Audio device found: name:DJM-900nexus vid="0x08E4" pid="0x0158" hardwareID:"66"
[10:19] Midi in device detected: \\?\usb#VID_08E4&PID_0158/605028352 (port:)
[10:19] Midi in device detected: \\?\usb#VID_08E4&PID_0158/605028352 (port:\\?\usb#VID_08E4&PID_0158/605028352)
[10:19] Midi out device detected: \\?\usb#VID_08E4&PID_0158/605028352 (port:\\?\usb#VID_08E4&PID_0158/605028352)
[10:19] MIDI Device Identifying: \\?\usb#VID_08E4&PID_0158/605028352 (in:0 out:0) (name: DJM-900nexus)
[10:19] MIDI Device Identified by PID/VID: \\?\usb#VID_08E4&PID_0158/605028352 : Pioneer DJM-900NXS
[10:19] Assigned Keyboard, type:0, index:1
[10:19] Assigned Pioneer DJM-900NXS, type:1, index:1
[10:19] MIDI Device Identifying: \\?\usb#VID_08E4&PID_0158/605028352 (in:1 out:-1) (name: Traktor Kontrol D2 - 1 Input)
[10:19] HID Device found, looking for definition. \\?\hid#VID_05AC&PID_8242/72351744
[10:19] HID Device found, looking for definition. \\?\hid#VID_05AC&PID_0236/73400320
[10:19] HID Device found, looking for definition. \\?\hid#VID_17CC&PID_1400/639696896
[10:19] HID Device found, looking for definition. \\?\hid#VID_0000&PID_0000/0
DJM 900nxs + NI D2
Posted Wed 29 Apr 20 @ 2:25 pm
OK, sent you an email to test something.
One more Q: I suppose when connecting multiple devices along with your D2, you are using the USB hub of the D2, yes|no?
If so, do you have enough USB ports to try connecting directly, or use some other hub, (and which one) ?
Also ,along with the tests i sent you by email, can you create an xml file (e.g. name it as Traktor Kontrol D2 hub.xml) , put it in VirtualDJ/Devices folder and have the following content
This will just ignore the MIDI device of the USB hub of the D2 (seen as MIDI, but probably not used at all). See if it reduces the amount of the additional CDJ/DJM units detected
<?xml version="1.0" encoding="UTF-8"?>
<device name="NID2HUB" version="800" description="Traktor Kontrol D2 hub" type="MIDI" vid="0x17CC" pid="0x1403" ignore="yes" hidden="yes" decks="1" >
</device>
Posted Wed 29 Apr 20 @ 5:20 pm
Got your email, working on that right now, I'll send you new Logs with the beta
I did it in both ways, using the D2 hub and without
I also have a 2 powered Hub but they didn't work that well
Also, along with the tests i sent you by email, can you create an xml file (e.g. name it as Traktor Kontrol D2 hub.xml) , put it in VirtualDJ/Devices folder and have the following content
Trying this right now
Ok sure
I'll let you know the results by email, thank you
A.
</device>
Ok sure
A.
Posted Wed 29 Apr 20 @ 6:28 pm
