Topic: VDJ 2020 is using twice the cpu then 8.3 with the pro skin
i have noticed that Virtual dj latest ver.b5478 using more then 60% cpu ! that is twice than the version i had before,
it seems like the new pro skin is using a lot of cpu, i installd again vdj 8.3 and the cpu went down to 28-30%.
macbok pro 2012 13 inch
i7 16gb ram 500sdd
osx sierra 10.12.6
i added a pic compering serato and traktor with vdj at the same macbook pro
Posted Mon 13 Jan 20 @ 2:17 am
So it is the skin or the update? What results do you get when using the old skin in the latest update?
You can also try setting experimentalSkinEngine to yes to lower cpu usage
using the old skin in the latest update the cpu goes down to 45%
setting experimentalSkinEngine to yes with the new skin on the latest update the cpu goes to 30%
experimentalSkinEngine, what does this setting do and why the new skin uses so much cpu ?
