On both latest build versions v8.4-64 b5454 (64 Bit) and v8.4 b5454 (32 bit) versions, when I record a mix and play back on VDJ the BPM speed is different, why ? Example, I recorded at 137 BPM when I load that finished track to play it says 152.13 that is way off. Also, the BPM analyzer continues to be off, this is after I manually adjust then set cues to it, when I come back the beats are slightly off again??? Is this contributing to this?
Currently I have Auto BPM set to OFF, Auto Match Key set to Off, all options are OFF. I was told by Chat (Bob) to set Auto reset to ON/ Yes and this still did not correct the issue? Please Advise, Thank you.
Posted Mon 09 Dec 19 @ 10:08 pm
