locodog wrote :
As far as I've found no it needs a string to be equal to. I'm willing to be corrected.
However after a day of not thinking about it I've an idea. [I wish I understood how my brain works that way (ツ) ]
How are you grouping? [what strings are you using, how many]
Example of a group: 80shiphophot
Or 90sR&BHot
Some have multiple groups like
2000sHipHopHot; 2000sR&BHot
Or 70sSoftRock
Posted Fri 15 Nov 19 @ 4:28 am
Nope, no work around that I can get to work, out of luck with this one.
multiple groups would have been a curve ball I can't figure out either
My idea was make a load of filter folders, 1 for each grouping, put them all as sideview shortcuts, then have an rsi get the masterdeck grouping data.
[side note @devs shouldn't masterdeck be a callable deck, something like; deck "masterdeck" action]
then +1 the sideview until sideview_title == grouping data
But that fell foul because sideview_title includes ".vdjfolder" and try as I might I can't create a var string with an action and a string. Then after that I was chasing my tail.
It could probably be done in a super limited fashion but it's a very long walk for a very short picnic.
Posted Fri 15 Nov 19 @ 10:14 am
"deck active" is probably the better choice, since it selects either the deck marked as master deck, or the deck currently playing when no master deck is set.
"deck master" actually originally selected the master deck, and still does for actions that don't work on master
Being able to use scripts in filter folders could indeed be an interesting addition for making more dynamic filter folders.
Posted Fri 15 Nov 19 @ 10:30 am
That's what I have now...
Posted Fri 15 Nov 19 @ 11:48 am
