Setup:
Ver. 8.3 b5186
Left, Center and Right monitors
VDJ is mostly used on the left monitor
Issue:
When the options are clicked, the submenu will show onto a different monitor.
This happens with Automix, Karaoke, Sampler
This is not the same as the prior version of VDJ
Here is an image of it: https://imgur.com/a/apejI6M
It does not matter what size the window is for VDJ. Full screen or Windowed.
I am viewing it normally at 1920x1080, but tried in windowed mode to see if it would go away.
Can you revert this back to the original way it was done?
Thank you kindly.
Ver. 8.3 b5186
Issue:
Thank you kindly.
![](/img/295995/71710/IMG_20190902_181346.jpg)
Posted Mon 02 Sep 19 @ 11:22 pm
reported many times now
one of the workaround until it is fixed: open info panel
Posted Mon 02 Sep 19 @ 11:29 pm
ahh okay. I did not see it prior.
thank you and I apologize for writing again.
I rarely look for support, so that is my mistake
Posted Mon 02 Sep 19 @ 11:32 pm
