Topic: SONGS LOADING WITH PITCH MESSED UP-HOW TO FIX?
Hi gang, so I notice on the new version some tracks will load with the pitch way up high or low. How do I or is there a setting that makes all tracks load to the pitch at ZERO?
Can I get the tracks that do this to load the proper way in the future?
Thanks.
Posted Wed 14 Aug 19 @ 1:01 pm
That sounds like autoBPMMatch is enabled
- that will change the BPM on load
It could also be smart play
- That will change the bpm on play (to sync to the other deck)
Or it could be that you haven't enable resetPitchOnLoad
- then the pitch slider will stay in place when a new track is loaded, and thereby potentially change the new track - like some hardware decks would do
Thanks Klaus, will check those settings & see if that solves the issue. Cheers.
Check PitchLock, put it on "No"
