could someone help me out a bit here..
1. want to add a custom button that let me adjust the position of CBG via the jogwheel (using touchscreen) when button is held down
2 want another custom button that let me adjust the length/size between 4:4 CBG, again with the jogwheel.
when button is actived
both buttons should work in both play and paused mode
Posted Mon 01 Jul 19 @ 10:12 pm
To change the behaviour you'll have to edit the skin tablet.xml.
I had a super quick look but couldn't see where you need to edit (it's early here)
Posted Tue 02 Jul 19 @ 6:21 am
