i just trie to buy the monthlu license of 19dollars in order to be able to use my numark mixtrack pro3 with virtual dj, i tried with different debit cards but it didn't work. The error message received is as follows:we are sorry that we are unable to complete the transaction at the moment contact support. What is the issue??
Posted Tue 30 Apr 19 @ 8:57 am
Como le instalo la licencias a mi virtual dj
Posted Mon 20 Jan 20 @ 8:48 pm
You buy it on the top of the screen whee it says "Buy" - then it automatically gets attached to your login, and you then use the same login when logging into the software
If you have a LE license key you type it in under "My Account" on this screen
Posted Mon 20 Jan 20 @ 8:53 pm
Ok gracias bro
Posted Mon 20 Jan 20 @ 9:08 pm
