Hi All
I can search MP3s but cant play them on VDJ Public Build 4720.1471.....unless I go to where they are on the HD and drag to Deck A or Deck B....
Help Please
Help Please
Posted Thu 27 Dec 18 @ 3:08 pm
I'd start with adding/re-adding to the database (goto the root of where the files and add to database) then, clean your database.
My theory is that, the files have been move outside of VDJ. When searched, it appears but it errors when trying to load into a deck because it's no longer on the original location where it used to be.
Posted Thu 27 Dec 18 @ 3:18 pm
Will give that a go THX
Posted Fri 28 Dec 18 @ 2:01 am
Problem Solved Thank You!
Posted Fri 28 Dec 18 @ 2:30 am
