Hi there,
I have just got VDJ2018 (V8.3 b4720)
On the version on my desktop computer it has "Grid Adjust" in the pads drop down box.
On my gig Laptop this setting does not appear.
Also, on the desktop, selecting Spiral gives the effect, but selecting it on my gig laptop makes the sound cut off.
On both coputers Wah Wah does not seem to do anything.
I am new to a lot of these features so there is a probability I am doing something wrong, or have not got used to the hundreds of options yet!!
Thank you & Merry Christmas,
Lee.
Lee.
Posted Mon 24 Dec 18 @ 2:25 pm
The effect issues are probably just effect settings. Try changing them
Posted Mon 24 Dec 18 @ 2:59 pm
Grid adjust pad page is not a default pad page. But you can add it from the extensions page
Posted Mon 24 Dec 18 @ 3:01 pm
Hi,
Thank you for your quick reply.
I have solved the grid-adjust issue by downloading it onto my gig laptop from the extensions page. **SOLVED** :-)
The only thing I don't understand is how it got onto the desktop in the first place??? I only installed VDJ yesterday onto both machines.....
Mysterious!
I will have a play with the effects settings, but at a glance they both appear to be set the same.
Spiral only has one adjustment "strength", but on the laptop, at any "strength" the sound just cuts off to silence.
Mysterious!
Posted Mon 24 Dec 18 @ 3:36 pm
