Topic: Is the new Pioneer DDJ-400 controller supported by VirtualDJ? - Page: 2
bonjour sur youtube le gard explique vous brancher votre controleur dj le systeme s installe touseul rien a faire sur pioneer on dit aucune mise à jours poure se modèle si en gros esque je doit achater une licence dj virtual compatible pour mon ddj-400 jais suivis scrupuleusement les infos option encore update ect,, sa été 1 mois hier soir j allume mon controleur comme a mette de la music un moment donner les curseur ne répondais plus il me dit clef licence puré ,, merci de me tenir aux courant francois
Please post in English (or use the French forum).
Your LE version was presumably supplied with a controller other than the DDJ-400. Therefore if you wish to use the DDJ-400 you will need to buy a license.
This is an English speaking forum, please use our French forum located here, thank you.
Quick question does anyone know if flac files can be played with Pioneer ddj 400 and Virtual Dj?
Yes
Next time please start a new thread.
Hi I need to buy virtual DJ mapping for my ddj 400
Can you help me ?
Buenas noches a todos tengo una licencia del pioneer DDJ-SZ para cambiarla por la del DDJ-400 que la estoy necesitando, escucho ofertas
como hago para reiniciar el vdj sera que pueden explicar paso a paso para que lea la pioneer ddj400
Hello,
On the default VDJ mapper for the DDJ-400, the main cue does not work!
The led is ok (it turns on when you click on it), but there is no sound!
I hope this will be quickly corrected in a future update?
Happy New Year!
Hey Guys, I have just purchased the Pioneer DDJ-400 and find it to be a great unit except, the jog wheels don't work. I am not a fan of the Rekordbox software that came with but love VDJ. I there a fix for this as everything else with VDJ and the DDJ-400 works fine.
Have you set the decks to vinyl mode?
Hello! FX SELECT doesn’t change the applied effect. What can I do? Thanks.
