never had this problem before, but on my VMS4 the volume slider gain on deck 2 is higher then the volume gain on deck 1 when playing the same track on both decks....how do i fix this so both decks give the same volume gain output when positioning both volume sliders in an equally lined up position. also, i would like to know how to adjust the volume sliders working only independently for each deck instead of both sliders effecting both decks. Deck 1 volume slider should just control deck 1 output only while not also controlling deck 2 or vice versa? any ideas?
Posted Sat 23 Jun 18 @ 6:21 pm
Is anyone going to answer this very important question?
Posted Mon 03 Sep 18 @ 2:09 am
Sounds like your sound config is wrong and it's pushing both output and monitor to one channel.
Have a look here and follow the setup guide: https://www.virtualdj.com/manuals/hardware/americanaudio/vms4/installation.html
Posted Mon 03 Sep 18 @ 2:11 am
