Hey guys Im recently organizing stuff and working more with pad pages. Really cool feature. (b4291)
however when I use sampler direct from pads they are not in beatsync! So they are in perfect sync when triggered from sampler pads, but same sample is not in sync when triggered from a pad page : sampler
I really would like to use this as I would have direct acces to 8 samples and still have my sidelist in view.
please help / inform me about this,. Thanks a lot!
Posted Sat 16 Jun 18 @ 1:04 pm
are these samples you have made yourself ?
how did you create them?
record loop is the easiest way as long as your beat grid is set up properly -> https://www.virtualdj.com/manuals/virtualdj8/interface/decks/decksadvanced/loops/index.html#recloop
Posted Sat 16 Jun 18 @ 2:04 pm
When you trigger samples from a deck, they will sync to that specific deck.
If you want them to always sync to the active deck, you'll have to change the pad page to something like
deck active sampler_pad 1
Posted Sat 16 Jun 18 @ 3:05 pm
hi Adion,
Thanks for reply! it worked. But now I have another issue: Can you help?
https://www.virtualdj.com/forums/224370/VirtualDJ_Technical_Support/need_help_with_sampler_(sampler_pad_page)___pad_pages___dj_controller_issue_.html
Posted Wed 27 Jun 18 @ 9:15 pm
