Topic: Script School - Page: 30.25
down is the same as while pressed, except down also has a not down part to the query
Ahhh. Thanks!
mg_1978 wrote :
locodog wrote :
param_equal there is checking against the literal string 'samplename', it needs backticks and get_var
there is almost nothing [only 1 case I can think of] you can actually do with a var by just name alone
i have quite know solution:
button: set ‘$samplename’ `get_browsed_title’ & browser_gotofolder ‘Sampler/Recordings’ & browser_window ‘songs’ & browser_scroll ‘top’ è repeat_start 20ms param_equal `get_browsed_title` `get_var ‘$samplename’` ? repeat_stop ‘scorri’ &sampler_edit : browser_scroll +1
not always work well, could you help me?
Eureka....solution is: browser_window 'songs' & browser_scroll 'top' & browser_window 'sidelist' & set ‘$samplename’ `get_browsed_title’ & browser_gotofolder ‘Sampler/Recordings’ & browser_window ‘songs’ & repeat_start 20ms param_equal `get_browsed_title` `get_var ‘$samplename’` ? repeat_stop ‘scorri’ &sampler_edit : browser_scroll +1
error is that browser_scroll 'top' it must be at beginning script (no inside script)
Scripting Help - pad_pushed script not specific to the pad number ?
i want to have any pad push change the color of the led jog , in the script below i have pad 1 set to do so , but i wasn't sure if there was a good way to go about doing this for all 8 pads.
Here is the script I have set on my led jog , i like feedback and colors...
not loaded ? color white : touchwheel_touch ? blink 0.25bt ? color red : color blue : pad_pushed 1 ? blink 0.5bt ? color white : color green : automix ? masterdeck? color green : color blue : leftdeck ? color magenta : rightdeck ? color cyan
A couple of ways, just chaining the queries is probably simplest
not loaded ? color white : touchwheel_touch ? blink 0.25bt ? color red : color blue : pad_pushed 1 ? blink 0.5bt ? color white : color green : pad_pushed 2 ? blink 0.5bt ? color white : color green : pad_pushed 3 ? blink 0.5bt ? color white : color green : pad_pushed 4 ? blink 0.5bt ? color white : color green : pad_pushed 5 ? blink 0.5bt ? color white : color green : pad_pushed 6 ? blink 0.5bt ? color white : color green : pad_pushed 7 ? blink 0.5bt ? color white : color green : pad_pushed 8 ? blink 0.5bt ? color white : color green : automix ? masterdeck? color green : color blue : leftdeck ? color magenta : rightdeck ? color cyan
locodog wrote :
looked ok, try this thinned down version
repeat_start 'colorTracks' ? on & repeat_stop 'colorTracks' : off & browser_window "songs" & browser_scroll "top" & repeat_start 'colorTracks' 100ms & ( get_browsed_song 'harmonic' & param_cast 'text' &
param_equal '01A' ? browsed_song color '#70ECD4' :
param_equal '01B' ? browsed_song color '#00EDC9' :
param_equal '02A' ? browsed_song color '#92F0A4' :
param_equal '02B' ? browsed_song color '#27EC82' :
param_equal '03A' ? browsed_song color '#B1EE86' :
param_equal '03B' ? browsed_song color '#85ED4E' :
param_equal '04A' ? browsed_song color '#E6E0A2' :
param_equal '04B' ? browsed_song color '#E0C86E' :
param_equal '05A' ? browsed_song color '#FEC8AC' :
param_equal '05B' ? browsed_song color '#FFA279' :
param_equal '06A' ? browsed_song color '#FFB3BF' :
param_equal '06B' ? browsed_song color '#FF8C93' :
param_equal '07A' ? browsed_song color '#FFB4D2' :
param_equal '07B' ? browsed_song color '#FF85B4' :
param_equal '08A' ? browsed_song color '#EBB7F9' :
param_equal '08B' ? browsed_song color '#F087D9' :
param_equal '09A' ? browsed_song color '#E7B6F8' :
param_equal '09B' ? browsed_song color '#CE93FF' :
param_equal '10A' ? browsed_song color '#C0CEFB' :
param_equal '10B' ? browsed_song color '#A1B9FF' :
param_equal '11A' ? browsed_song color '#94E5F8' :
param_equal '11B' ? browsed_song color '#3ED2F8' :
param_equal '12A' ? browsed_song color '#50EBF0' :
param_equal '12B' ? browsed_song color '#01EDED' : )
& browser_scroll 'bottom' ? repeat_stop 'colorTracks' : browser_scroll +1
I really like this script.
Just wondering could it be possible to make files matching the master deck in BPM, Key and Grouping start blinking?
blinking; no possible way.
bpm is dynamic but only numbered beat difference not % beat difference,
so precision falls apart for fast or slow bpms [depending on which you're biased to]
Key difference is dynamic but not strict matches only compatible
Grouping isn't dynamic at all
I can't do any plugin tricks like sticky because setting colorRules can't be accessed by script.
you couldn't even have a scroll evaluate & send to sidelist thing due to how you've got multiple groupings on one track.
best you can do is build a string dynamically with bpm % range and strict key then cast that as text to a quick_filter.
It won't be colours only a quick filter & you'll have to pick the bones out of grouping, as that's unique to your workflow.
Oh you'll have toggle the filter as deck master track changes to update for any bpm changes.
custom_button
quick_filter 0 ? on & quick_filter off :  off & get_text "Bpm < `param_multiply 1.04 'deck master get_bpm'` and Bpm > `param_multiply 0.96 'deck master get_bpm'` and key is `deck master get_key`" & param_cast 'text' & quick_filter
current bpm is +- 4%, you can change that with the numbers next to param_multiply
Thank you !
Hi,
is there a way to get a true/false Value about get_status
has status true, has no status false
first thought is compare against a blank string, I'll check now
*edit* yeah that does it.
param_equal `get_status` "" ? on : off
Wow.. I've test so much things with param_equal and param_bigger the `` was the key :D....
There are many moment i cry with the Virtual DJ Script :D
THANK YOU
yeah the thing is with param_equal, it can do strings or actions, so while param_bigger doesn't need `` [but still can use] because it can't deal with strings and it uses '' or "" to encapsulate actions that include a space like
param_bigger 'get_var a' 'get_var b'
because param_equal can do strings, then it needs the action to be specified as an action, by wrapping in `` and strings wrapped in "" or ''
It's a little messy as a rule set but to clean it up would remove capabilities.
...script, it's a language, and languages have these weird nuances that a first are confusing but there's usually a reason as to why.
Hi. Can a script count the number of letters in a string?
set_var 'a' "text"
How many letters are there in the variable 'a'?
setting another var to your first var with param_cast 'text' X, [X being the number of chars to cast] then comparing for equality.
set_var 'a' "text" & set b `get_var a & param_cast 'text' 1` &
var_equal "a" "b" ? SIZE OF 1 :
set b `get_var a & param_cast 'text' 2` &
var_equal "a" "b" ? SIZE OF 2 :
set b `get_var a & param_cast 'text' 3` &
var_equal "a" "b" ? SIZE OF 3 :
set b `get_var a & param_cast 'text' 4` &
var_equal "a" "b" ? SIZE OF 4 :
truth be told you don't even need a 2nd var, same sort of idea but with param_equal
param_equal `get_var a` `get_var a & param_cast 'text' 1` ? SIZE OF 1 :
param_equal `get_var a` `get_var a & param_cast 'text' 2` ? SIZE OF 2 :
param_equal `get_var a` `get_var a & param_cast 'text' 3` ? SIZE OF 3 :
param_equal `get_var a` `get_var a & param_cast 'text' 4` ? SIZE OF 4 :
Perfect!!!
Thank you !
Someone asked for a midnight countdown video effect, but I was thinking that it would maybe be simpler to add it to a video skin
But that will need some scripting
I assume the value could then be taken from comparing 23:59:59 to get_clock cast to maybe an integer, then param_multiply -1 and param_add to get the difference, maybe adding the missing second, and then showing the value?
But I can only figure out how to do the first few steps...
I've done it, I just need to remember how I did it.
*edit, I found it and I remember the problem now. It needs to be started at a known time.
[it monitors saved clock state v current clock and if different, -1 from the countdown, some maths, and resave new clock state]
Problem root is, get_clock, it returns a string so it will only cast the hour value as an int [the : breaks it]. And we've got nothing for casting substrings.
get_clock 'hour'
get_clock 'min'
get_clock 'sec'
would be one fix, for this specific problem, but that isn't real script currently.
param_cast 'text' SIZE INDEX
would be another more round about fix, it would have other uses too, but again doesn't exist.
I suppose it could be brute forced to get the time in a usable form but that would be pretty ugly.
[I'll see how it looks]
Or windows I could make a plugin
I'll add a countdown script to make this easier
thanks that would be good, I've just done the script way anyway.
not easy I suppose I'll post it here in the off chance I need it in the future,
plus to remind myself how to do stuff
get hour,min,sec as vars
timer to midnight
send to text plugin
deck master repeat_start runClock ?
var $showCount 1 ?
on & set $showCount 0 & deck master effect_string 'text' 2 "GENERIC MESSAGE" : off & set $showCount 1 & deck master effect_active text on :
set $showCount 1 & deck master effect_active text on & deck master effect_string 'text' 2 "COUNTDOWN" &
set $minString `get_clock 24 & param_cast 'text' 5` &
set $secString `get_clock 24` &
set $hours `get_clock 24 & param_cast 'integer'` &
set $min 0 &
set $sec 0 &
set $time `get_var $hours & param_cast '00' & param_cast 'text'` &
set_var $char ":" &
set $time `param_add 'get_var $char' 'get_var $time' & param_cast 'text'` &
set $time1 $time &
( param_smaller 10 `get_var $min` ? set $min `param_add 'get_var $min' 'get_text "0"'` : ) &
set $time1 `param_add 'get_var $min & param_cast 00' 'get_var $time'" & param_cast 'text'` &
repeat_start_instant minRun 25ms 60 &
var_equal "$minString" "$time1" !?
set $min `param_add 'get_var $min & param_cast "integer"' 1` &
( param_smaller 10 `get_var $min & param_cast 'integer'` ? set $min `param_add 'get_var $min & param_cast "text"' 'get_text "0"'` : ) &
set $time1 `param_add 'get_var $min & param_cast "text"' 'get_var $time' & param_cast 'text'` :
repeat_stop minRun &
set $time `param_add 'get_var $char' 'get_var $time1'` &
set $time1 $time &
( param_smaller 10 `get_var $sec` ? set $sec `param_add 'get_var $sec' 'get_text "0"'` : ) &
set $time1 `param_add 'get_var $sec & param_cast 00' 'get_var $time'"` &
repeat_start_instant secRun 25ms 60 &
var_equal "$secString" "$time1" !?
set $sec `param_add 'get_var $sec & param_cast "integer"' 1` &
( param_smaller 10 `get_var $sec & param_cast 'integer'` ? set $sec `param_add 'get_var $sec & param_cast "text"' 'get_text "0"'` : ) &
set $time1 `param_add 'get_var $sec & param_cast "text"' 'get_var $time' & param_cast 'text'` :
repeat_stop secRun &
repeat_start_instant correction 25ms 6 &
var_equal "$time1" `get_clock 24` !?
set $hours `get_var $hours & param_cast 'integer'` &
set $min `get_var $min & param_cast 'integer'` &
set $sec `get_var $sec & param_cast 'integer'` &
( cycle $sec 60 & var $sec 0 !? : cycle $min 60 & var $min 0 !? : cycle $hours 24 ) &
set $time3 `get_var $hours & param_cast '00' & param_cast 'text'` &
set $time3 `param_add 'get_var $char' 'get_var $time3' & param_cast 'text'` &
set $time3 `param_add 'get_var $min & param_cast "00"' 'get_var $time3' & param_cast 'text'` &
set $time3 `param_add 'get_var $sec & param_cast "00"' 'get_var $time3' & param_cast 'text'` &
set $time1 $time3 :
repeat_stop correction &
set $countdown `param_add "param_multiply 'get_var $hours' 3600" "param_multiply 'get_var $min' 60"` &
set $countdown `param_add "get_var $sec" "get_var $countdown"` &
set $day 86400 &
set $countdown `param_multiply "get_var $countdown" -1 & param_add 86400` &
set $time `get_clock 24` &
repeat_start_instant runClock 25ms &
var_equal $time `get_clock 24` !?
set $countdown -1 &
set $cdHour `param_multiply 'get_var $countdown' 'get_constant 3600 & param_1_x' & param_cast 'int_trunc'` &
set $cdMin 0 &
set $cdSec `param_mod 60 'get_var $countdown'` &
set $cdMin `param_add 'param_multiply "get_var $cdSec" -1' 'param_multiply "get_var $cdHour" -3600' ` &
set $cdMin `param_multiply "param_add 'get_var $countdown' 'get_var $cdMin'" "get_constant 60 & param_1_x"`&
set $time3 `param_add "get_var $char" "get_var $cdHour & param_cast '00'" & param_cast 'text'` &
set $time3 `param_add "get_var $cdMin & param_cast '00'" "get_var $time3"` &
set $time3 `param_add "get_var $char" "get_var $time3"` &
set $time3 `param_add "get_var $cdSec & param_cast '00'" "get_var $time3"` &
( var $showCount 1 ?
get_var $time3 & param_cast & deck master effect_string 'text' 2 : var $showCount 2 ? deck master effect_string 'text' 2 "Happy New Year!" : ) &
param_equal `get_var $time3` "00:00:00" ? set $showCount 2 & wait 1000ms & repeat_stop runClock & wait 29000ms & deck master effect_active text off & set $showCount 0 & deck master effect_string 'text' 2 "GENERIC MESSAGE" : :
I played with it a little bit just see second by second changes, this uses text presets for size font & position, so it will only work if you have them saved ["time","number","message" in my case]
this bit replaces the end bit
( var $showCount 1 ? effect_string text 3 "time" &
get_var $time3 & param_cast & deck master effect_string 'text' 2 : ) &
param_equal `get_var $time3` "00:00:10" ? set $showCount 0 & effect_string text 3 "number" & effect_string text 2 "10" :
param_equal `get_var $time3` "00:00:09" ? set $showCount 0 & effect_string text 2 "9" :
param_equal `get_var $time3` "00:00:08" ? set $showCount 0 & effect_string text 2 "8" :
param_equal `get_var $time3` "00:00:07" ? set $showCount 0 & effect_string text 2 "7" :
param_equal `get_var $time3` "00:00:06" ? set $showCount 0 & effect_string text 2 "6" :
param_equal `get_var $time3` "00:00:05" ? set $showCount 0 & effect_string text 2 "5" :
param_equal `get_var $time3` "00:00:04" ? set $showCount 0 & effect_string text 2 "4" :
param_equal `get_var $time3` "00:00:03" ? set $showCount 0 & effect_string text 2 "3" :
param_equal `get_var $time3` "00:00:02" ? set $showCount 0 & effect_string text 2 "2" :
param_equal `get_var $time3` "00:00:01" ? set $showCount 0 & effect_string text 2 "1" :
param_equal `get_var $time3` "00:00:00" ? set $showCount 2 & effect_string text 3 "message" & deck master effect_string 'text' 2 "Happy New Year!" &
56%
