the only fields that update from track on deck are; bpm difference & key difference.
any other field would need a filter writing via plugin, or an unreasonable amount of bruteforce to cover every possibility.
Since you didn't get on with 'sticky', I'd say it's not viable currently.
Posted Wed 29 Jun 22 @ 9:13 pm
As it is I have to click on it to update it...and I'm ok with that. I just need the proper script to search the grouping field and collect matches. I have come to understand it doesn't auto update but I'm ok with that.
Posted Wed 29 Jun 22 @ 10:12 pm
+1
Posted Sun 03 Jul 22 @ 2:25 am
Hey, I want to change the fontsize of the cuenames in the wave-window of the skin.
They are so small that I can´t read them when I´m performing on stage.
So I have to go to the skinfile and change maybe just a number, but WHERE?
I´m using the haunting pro touch-skin by Alex RDZ96.
Thanks in advance for any help
(I posted the question in the skin-area, but didn´t get any answer. Next Gig on Saturday...)
Posted Wed 17 Aug 22 @ 2:21 pm
Solved!
In Skinfile there is the panel [panel name="defaultwave4deck"]
there under "Cue" the font can be changed or resized.
Posted Thu 18 Aug 22 @ 11:37 am
Hi! Why not yet add by VirtualDj team scripts about see in a monitor sample time remaining or sample time elapsed, when a sample is playing? i can see only with script sampler_position a sort of “time passage” when a sample is playing :( is there another solution??
thanks
thanks
Posted Tue 20 Sep 22 @ 8:29 am
Is it possible to select a deck by using value of variable?
What I want to do is to select "previous" deck. Here's a naive version
get_deck 1 ? deck 4 select : get_deck 2 ? deck 1 select : get_deck 3 ? deck 2 select : deck 3 select
Posted Tue 20 Sep 22 @ 4:28 pm
Hi, I'll try here.
In the variable I have the text (name of the effect)
How do I change the colorfx effect with this variable?
doesn't work.
It is very impractical to do that
set_var 'DeckColorSelect' "Echo"
filter_selectcolorfx '`get_text "ColorFXSelect"`'
doesn't work.
var_equal 'ColorFXSelect' '`get_text "Cut"`' ?
filter_selectcolorfx "Cut" :
var_equal 'ColorFXSelect' `get_text "Echo"` ?
Posted Thu 22 Sep 22 @ 8:24 am
Mirda Draxal wrote :
Hi, I'll try here.
doesn't work.
doesn't work.
Someone in the FB group answered it
In one combined script for testing:
set_var 'DeckColorFX' "Echo" & param_cast 'DeckColorFX' & filter_selectcolorfx
Posted Thu 22 Sep 22 @ 9:24 am
Thanks, it works.
I didn't notice on FB
Posted Thu 22 Sep 22 @ 6:11 pm
Hi,
I think there is an error when loading the name of the ColorFX effect when setting Filter (it loads as Filter). Please try the following script
filter_selectcolorfx "Filter" &
set 'ColorFXSelect' `filter_label "name"` &
var_list & wait 1000ms &
filter_selectcolorfx "Cut" &
wait 1000ms &
set 'ColorFXSelect' 'ColorFXSelect' &
param_cast 'ColorFXSelect' & filter_selectcolorfx
Posted Sun 25 Sep 22 @ 7:29 pm
hi, i use Sidelist like a Sequencer…and in my Sidelist i have “Sequencer” samples, but any time i open VirtualDj my Sidelist is empty..so when i use a mapped specific play button in my Pioneer DDJ-RZX….i don’t have samples. I would load a “Sequencer” playlist (i have saved my sidelist like a playlist, and it’s name is “Sequencer”) at first play:
Sequencer Play button: browser_window ‘sidelist’ & file_count ‘sideview’ & param_equal 0 ? browser_gotofolder ‘Playlist’ & browser_scroll +1 & get_filename & param_contains ‘Sequencer’ ? sidelist_load & play : browser_scroll +1 : play
but doesn’t work correctly :( can you help me???
Posted Sat 01 Oct 22 @ 3:05 pm
solved: for help everyone:
browser_gotofolder ‘Playlist\Sequencer’ & sidelist_load & play
work! i thinked that browser_gotofolder was only for folders, is for file (Sequencer is a file Sequencer.m3u) directly too 👍
Posted Mon 03 Oct 22 @ 9:45 am
Hi,
wait 1000ms &
Solved. It is better to ask for the current name of the colorfx effect
set 'ColorFXSelect' `filter_selectcolorfx`
This will return the correct name "FILTER"
I still don't understand why when I select the FILTER effect appears as the colorfx name FILTR.
Posted Tue 04 Oct 22 @ 5:08 pm
Perhaps a bug in the language file you use?
Posted Tue 04 Oct 22 @ 5:17 pm
I want to setup the stems padpage to match seratoDJ stem pad setup...
Posted Wed 05 Oct 22 @ 7:53 am
You're right!!
Translation error.
Posted Wed 05 Oct 22 @ 7:17 pm
Hi.
How to select a deck using a variable?
This script is broken.
set 'a' 1 &
deck 'a' &
(deck action)
Posted Wed 05 Oct 22 @ 7:42 pm
That never worked so it can't be called broken. query the var against a value, if true select the deck in long form.
could select accept a param? [it doesn't] syntactically it could, but most cases a bracketed query is a fine solution.
Posted Wed 05 Oct 22 @ 8:49 pm
hi at all! i would map a button that pushed “holding” 700ms set ‘variable’ 1 while_pressed, not holding make action1:
button= holding 700ms : set ‘variable’ 1 : var ‘variable’ 1 ? set ‘variable’ 0 : action1
could you help me? thanks
Posted Thu 06 Oct 22 @ 6:05 am
