@DJ Riot Grrrl, I've got the thing for you. Needs a plugin to add action scripts. And what the action is going to be is very opened
this is my working for action poi for OS2L, use subtitles, but can be tweaked to do any action
PM or chat here, on the sort of thing you want to add
Posted Mon 15 Nov 21 @ 6:29 pm
Hey guys,
I am using the Inpulse 500 with VDJ 2021. There I have 4 FX Buttons. Two left and two right. On Click I want the left buttons to activate a certain filter on DECK 1 and the right Buttons to activate a certain filter on DECK 2. If the filter is activated it should be deactivated. I tried coding it my self. But I failed. Can some help me:
On Click:
Case 1: Filter X is not activated. Filter X gets activated.
Case 2: Filter X is activated. Filter X get deactivated.
Can you tell me how I can do this? Also I have two knobs for the filters. What is the right code for the knob to change the filter?
Thank you so much in advance!!!
On Click:
Posted Fri 19 Nov 21 @ 10:35 am
@golnar, should be covered here
FX slots & FX active
effect_select, effect_select_multi
fx buttons & sliders
Posted Fri 19 Nov 21 @ 12:48 pm
hi. is there a script for push browser encoder that make:
browser_folder if folder have subfolders, if folder haven’t subfolders go to browser_windows ‘songs’
thanks
thanks
Posted Mon 22 Nov 21 @ 11:21 pm
like this
browser_open_folder & browser_open_folder ? : browser_enter
Posted Mon 22 Nov 21 @ 11:55 pm
mg_1978 wrote :
hi! i have mapped an encoder that move a sample in sideview ‘sampler’ with var ‘samplermove’ 1:
encoder: browser_window ‘sampler’ ? var ‘samplermove’ 1 ? param_smaller 0 ? browser_move -1 : browser_move +1 : nothing : nothing
but, for example, if i move sample 1 to 3 position and i play with pad 3 i can’t listen new sample in position 3, but i listen old sample 3 :( is not a really moving with script ‘browser_move’?
thanks who help me
thanks who help me
solved :) with script:
encoder: param_smaller 0 ? sampler_select & sampler_move -1 : sampler_select & sampler_move + 1
but with sampler_select is open a window..with a script can i close this window?
i would post a little video but i can’t upload here :(
Posted Tue 23 Nov 21 @ 9:40 am
sampler_move -1 isn't a script, you mean browser_move?
why call sampler_select at all?
Posted Tue 23 Nov 21 @ 10:03 am
-sorry, is browser_move -1 / browser_move +1
- sampler_select yes is generic (at all) because if i script: param_smaller 0 ?sampler_select 1 & browser_move -1 : sampler_select 1 & browser_move +1
(1 is an sxample) i can move only sample in slot 1..i wont move any sample focused, but sampler_select open a popup window...can i close this popup window with a script?
Posted Tue 23 Nov 21 @ 12:43 pm
so don't use sampler_select.
use, browser_window 'sampler' & browser_scroll 'top' & browser_scroll +X & browser_move +1
a lot of the time that is scripting, sometimes there's knowing a nice easy concise action, most times however, you do it in steps.
Posted Wed 24 Nov 21 @ 6:37 pm
since the stock echo isnt a good echo I need a script that i can assign to a button that activates a solo vocal stem, then turns on BFX-Echo and the stock echo. The BFX-Echo should turn off after the timing set in the BFX-Echo settings with the stock echo acting as it normally does.
Posted Thu 25 Nov 21 @ 2:26 pm
What have you tried?
Posted Thu 25 Nov 21 @ 3:31 pm
locodog wrote :
I got the echo part deck left effect echo activeWhat have you tried?
Posted Thu 25 Nov 21 @ 4:54 pm
So tried not much. [given you just copied v7 script from your controller]
stem solo you've been shown recently [search stem in the mapping window if you can't remember], the fx(s) active you know [but v8 syntax is effect_active "Name" ] the only thing that isn't straight forward is the fx off timing by an fx setting, that will be a list of queries against the fx buttons, when true start a single repeat_start with a bt for the time parameter
....effect_button "BFX-Echo" 1 ? repeat_start 'NAME' 0.125bt 1 & TURN BFX OFF : QUERY SECOND BUTTON etc
I can't see this being what you're after bfx doesn't trail on stop, so bt being same as fx, you're just feeding the stock echo with extra steps.
Posted Thu 25 Nov 21 @ 5:44 pm
actually Im feeding the stock echoe the the echo i like which makes the bfx echo the echo trails the made by the stock echo. giving me the volume of the echoe that I need when transitioning or even with just using the echoe during the song.
Posted Thu 25 Nov 21 @ 6:02 pm
locodog wrote :
like this
thanks! but isn't completely what i would, because after opened a folder with subfolder. focus is in browser_window 'songs' and not only open a folder with subfolder, bit if focus is in subfolder....yes it can move to browser_window 'songs'
Posted Thu 25 Nov 21 @ 10:12 pm
Not an easy script, I don't know how you get me for the money.
set '$tab' `get_browsed_folder_tab` & browser_open_folder & repeat_start 'name1' 50ms 1 & browser_scroll +1 & param_equal `get_browsed_folder_tab` `get_var '$tab'` ? browser_scroll -1 & browser_enter : param_bigger `get_browsed_folder_tab` `get_var '$tab'` ? browser_scroll -1 & browser_enter : browser_scroll -1
Posted Fri 26 Nov 21 @ 10:51 am
I used to think I was fairly intelligent until I came across vdj script. Now I feel dyslexic.... I just dont get it and whenever I try I destroy my mapping. I give you guys a lot of credit and respect cause I just dont get it.
Posted Fri 26 Nov 21 @ 5:48 pm
@xxx
make a make backups and give it a go, it's a language some people aren't wired for that [I'm not], consider this thread and the verb list a phrase book & dictionary, to actually learn you have to use the language. Even if it's trivial simple stuff, keep repeating it until you can't forget it. Eventually when a few concepts have burnt in the verb list stops appearing vague, it appears concise.
Posted Fri 26 Nov 21 @ 7:01 pm
thanks a lot my friend...I took a idea from your script and i have now my solution!
browser_window 'folders' ? param_equal `browser_open_folder` `on` ? browser_window +1 : get_browsed_folder_tab & param_bigger 1 ? browser_window +1 : browser_open_folder 'on' : browser_window +1
Posted Fri 26 Nov 21 @ 9:35 pm
cool if that works, [your tree must be structured a specific way]
Posted Fri 26 Nov 21 @ 9:56 pm
