Topic: Script School - Page: 12.75
i have written this script in a “pad editor name” for have 2 information in a pad1 (for example) layout: get_text “ `sampler_volume_nogroup & param_cast ‘integer’ ` \n `get_sampler_name 1 `”
but i can see only sampler volume 1 in %, i can’t see under (I would like it to wrap up) nothing :( can you help me?
thanks!!!
Because script is bad and actions used are wrong
`sampler_volume_nogroup` \n`get_sample_name 1`
or
`sampler_volume_nogroup` \n`get_sampler_bank`
or
sorry but this scripts doesn't work :(
strange... they wouldn't work in b61xx and earlier without at least one leading space
was fixed in b62xx
in 63xx it needs the leading space (or other chars) again
" `sampler_volume_nogroup` \n`get_sample_name 1`"
" `sampler_volume_nogroup` \n`get_sampler_bank`"
without the double quotes of course ^^
was fixed in b62xx
i think there is a little bug in last version
6294 because my friend have controller Nunark NV and in it’s display default mapper (effects section) there is “action 1\naction 2” but don’t work now :(
mg_1978 wrote :
was fixed in b62xx
Eureka! i have understand problem :) is the skin! with PRO skin works better.....with PERFORMANCE skin don't work....
hi! if i would only 5 letters about sampler name is correct this script?
- get_sample_name 1 & param_cast ‘text’ 5
i think is correct but don’t work :(
Vci400, using 4 decks, setting Ducking Echo activate. Mapping has to be set for decks 1 and 3 which are the left side. This is what I came up with by truncating the mapping that was used to mimic a post fader effect before the software add a post fader effect. I thought it would work but it doesn't.
@3X just strip it out, as far as I remember work around pffx was a button and a crossfader script, button; delete the mapping. crossfader change it back to just
crossfader.
if you're wary of killing your mapping just make a copy, experimenting with this kind of stuff is risk free.
@mg_1978 tested here without problem
warn the quotes in your post were not correct ones, must be simple quote or double quotes and are optional here :
get_sample_name 12 & param_cast text 4
just to rememder :
leftcross ? deck all leftcross ? xxxx : : rightcross ? deck all rightcross ? xxxx : : xxxx
will do xxxx on all the decks affected to the same crossfader side as calling deck or to the calling deck only if not affected to crossfader
usefull even with more than 4 decks
Nicotux wrote :
just to rememder :
If this was for me, you just lost me....
@3X vars have no place with default fx, neither sides/deck really
effect_active 'ducking echo'
post fader fx before official was a patchwork, press this - turn on some fx - trigger a var, var lets the XF script know to use a variation script.
a work around but at the time that made the impossible possible, I don't know if the devs adopted any of my methods or thinking, but I believe my bodge attempt - at least - somewhat encouraged official.
All that said, after poking around new stuff, effect_stems currently isn't post fader, so the method isn't completely dead
Is it possible to work with you on reworking the mapping to fit today's software structure?...
I got beer money
yes work! thanks (i was wrong to write)
hi! i would map a button like “mic_talkover”, but for line input! because my microphone is used by soundcard that is connected in line 4 my controller. If button is toggle i have mapped:
button: toggle ‘talkover’ and var ‘talkover’ 1 ? get_vu_meter ‘linein’ ? deck all volume 20% : volume : volume
but don’t work :( can you help me??
[quote=locodog]@3X vars have no place with default fx, neither sides/deck really
Ok this works on deck 1 but does not when I switch the left side to be deck 3.
because deck 1 is deck “select”.....i change this:
leftdeck ? action_deck 1 ? deck 1 effect_active ‘ducking echo’ : deck 3 effect_active ‘ducking echo’ : action_deck 2 ? deck 2 effect_active ‘ducking echo’ : deck 4 effect_active ‘ducking echo’
24%
