Topic: MSB/LSB Problem
Hi,
I've owned a Voyager now for 5 months. It is perfect and since purchasing it I've had a hard time using any other synth since.My only problem is automating parameters that use MSB/LSB. Is there really no easy way to draw automation sweeps in a DAW sequencer without the zipper/step effect happening? It's seriously driving me crazy as it seems NO ONE on the internet seems to have an answer to this problem.
Please help.
I didn't find the right solution from the Internet.
References:-
https://forum.moogmusic.com/viewtopic.php?q=forum/viewtopic.php&f=2&t=10477
Online Business Advertising Campaign
Thanks
Posted Thu 05 Apr 18 @ 8:21 am
It would be up to your DAW to support 14-bit MIDI elements.
Since this topic has nothing to do with VirtualDJ in general please ask on the forums / support section of the DAW you're using.
PS: VirtualDJ itself can use both 7 bit and 14 bit MIDI elements.
Posted Thu 05 Apr 18 @ 8:33 am
I'm sure you will find a solution to your issue by going to a relevant source. You can find anything on the internet if you look really hard, thank you.
Locked by AMAHM
Posted Sat 07 Apr 18 @ 8:33 am
