Hi Guys
I would like to see a sticky whereby we can visit for recommendation of lighting equipment as an example,
As a mobile DJ I pretty much got a lot top spec lighting in my opinion. I purchased lighting last year and tried it but returned four different units as I didn't think them suitable for long term use. I don't want to get into rubbishing companies or their equipment , but just a recommendation of lighting or other equipment which is above and beyond what you expected of it.
I was looking for Par cans which were the similar spec used on stage in theatres. I purchased a pair of 180 watts led multi colored with UV here in the UK , i then find the same design from china 324 watt for less money £160 , plus £18 customs charge. I saw the same priced up for just less than £500 so a big markup.
The only issue with buying from China is the high price to return them from the Uk as I guess the same from any other country in the main.
These Pars I can recommend but not advertising here yet as I don't know if we are allowed too.
I will leave it at that for the time being as there May be a page in existence which Iv overlooked.
Cheers
Chris
Cheers
Chris
Posted Thu 18 Jan 18 @ 3:04 am
I think there is also no repairing possible in case of troubles.
Posted Sat 20 Jan 18 @ 2:19 am
